'97 YZF750 clutch master and '03 R1 front brake master
Started by Harvy, November 04, 2010, 09:36:38 PM
Here is a pretty lousy pic
Front brake now has 5 way lever adjustment and the clutch is 4 way adjustable.
The most notable change is with the clutch.......it is now oh so smooth and light at the lever.
I used the OEM mounting bracket for the clutch reservoir with a couple of appropriate bends so that it is attached using the top perch mounting bolt.
