Cafe Racer Project
Started by FJ Aussie, November 04, 2010, 05:54:48 AM
FJ Aussie
Hello all,
Yes have decided to turn our 89 model fj1200 into a Cafe Racer project.Will get some piccies soon with the progress.Was wondering though about the clip ons.First to find out what the diameter is exactly of the front suspension and if anyone has bought these drop bars and where did they get them from?
Thanks in advance Pete
your 89 tubes are 41mm and you can use the clip ons from a 87-88 fzr 1000. they will go under the top triple.
FJ Aussie
Cheers For the info. Does that mean if I use the fzr gear can I still you all the FJ1200 throttle,blinker etc setup or go the way of FZr 1000?
May be different connectors or something, but everything should interchange, well, interchangably :)  The bars will be a standard 7/8" size, mirror mounts aren't on the bars on the 89 model, but the switchgear should work without a hitch.
Length could be a problem, but shouldn't be.  And the bar ends may or may not fit (might have to swap to FZR ones).  Clearance at the tank will be the bigger problem, if you're making a different tank to fit nearly anything that fits a 41mm fork would work.  I've even seen tiny vespa switchgear used on cafe bikes, makes for a subtle touch.
alfred
I really look forward to see how your bike turn out - please keep us updated. I`m thinking of maybe doing the same thing...
FJ Aussie
Will do alfred.We hare ordered some clip ons and other bits so once we have them on the bike will post some piccies up.
alfred
Shouldn`t you be out in the garage now ?????  (popcorn)
FJ Aussie
Yes I know I have been a slack ass.Have the cars on now just have to put a bit more of the switchgear on and will take some piccies. :drinks:
