without central stand
Started by las1200, October 21, 2010, 07:09:49 PM
las1200
Hi,
As an unexperienced FJ owner I wonder how do I maintain my bike without a center stand? (FJ1200 ABS '92)
I mean oil change, brake fluid with leaned bike... etc.
Any tricks?
billwest
You could invest in a pit stand (paddock stand), such as this one:
Sold it!
Yamifj1200
The center stands come up from time to time on ebay or someone here might have one to sell. The FJ's came from the factort with them installed. Perhaps the previous owner removed it for some reason...
Eric M
Las, oil can be drained out of the l/h oil cooler connection in the pan if you can't find a centre stand.
Or how about draining it most of the way while on the side stand, then holding the bike upright for a few minutes while the remaining last bit drains out?
As was previously mentioned, without a center stand, the pit stand (rear stand) is a good way to be able to service the chain etc.  If you want to spend the $$ the best stand, in my mind is the Cyclecat USC1.  It'll lift the bike gently off the side stand, and drop it back down gently for you.  Pit Bull also makes a popular standard style one that you'll need to lift the bike off the side stand yourself with.  Most folks don't have too much trouble once they get the process down.
Here's a guy demoing the cyclecat with two fingers...
Cyclecat
las1200
Thanks everyone for the advice. :yes:
So I decided to look for a used original centerstand. Found manny in gemany on ebay.
The question now is if there is any difference in centerstand from fj model to model or are all the same?
I own a '92 Fj1200 abs.
Travis398
any year stand should work, But I am not sure about the bolts.
i would try to get either a 91, 92 or 93 year centerstand and hardware... the rubber mounted frames are considerably different from the earlier years.
KOokaloo!  :good2:
tqmx1
If the bike has a aftermarket exhaust that might explane why the center stand was removed.
las1200
Yes you're right. Probably means it had some different exhaust in the past but these are new and yamaha stock so hope will fit ok.
Bob
Quote from: tqmx1 on October 23, 2010, 12:33:27 PM
The JMC swingarm on my '93 prevents me from using the central stand, so I put in on when doing maintenance.  It only takes a minute and I can switch it all by myself; don't need someone else to hold up the bike to get it upright.
Bob N.
'93 FJ
'17 V-Strom DL650
Whitby, ON
las1200
received and installed central stand today. :yahoo:
Fitted perfectly because i have stock exhausts.
Found impossible to raise her alone thow. Only with a helping hand of my son pushing her backwards!
Still missing rubber stopper on left exhaust. Will find something that fits...
carsick
Quote from: las1200 on November 02, 2010, 04:10:54 PM
Is the bike lower than stock? Shorter tire, forks raised in the triple clamps, longer dogbones etc. make it much harder to raise the bike on the stand. And also, are you pulling UP on the handle under the tail? Both of these make a big difference.
Travis398
Quote from: carsick on November 02, 2010, 04:31:38 PM
Age seems to make a difference too, Of course I am young, but I noticed my bike doesn't pop up on the center stand like it use to.
(popcorn)
Yamaha still makes them, and they really aren't that expensive
Flying Scotsman
When I bought my 85 it had no c/stand.picked one up from a member and put it on  :shok:
I could not get it up on the stand  :shok
I took it off and had someone explain how to do it so I went and put it back on and tried again.She poped right up no problem.
Have someone show you how to do it it will help you to see it done first.
1990 FJ1200
1999 GP1200 (165 + hp)
