Not an FJ........what is it?
Started by Harvy, October 13, 2010, 06:42:43 PM
Can anyone identify this bike?
The current owner says its a v-twin....... but I'm thinking it may be a VF700 Interceptor     :unknown:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=270645287492&ssPageName=STRK:MEWAX:IT
yamahammerFJ
Right on the money, it appears to be a vf700. Maybe he's confused since it's a V-4?
1985 FJ 1100 - 3CV forks/wheel/brakes
GSXR 17x5.5 swap almost complete!
Remus exhaust - brand new carbs
Travis398
Looks like it could be an '84 (in the states anyways)
Yep, that's what it looks like... not sure if the wheels are stock, though.  I don't remember seeing any like that on a VF here in the States.  They look similar to the ones on the CX500 turbo, but IIRC, it was shaft drive
I sold my VF700 to buy my FJ.
Thanks guys......
Randy.....any good for a do'er up'erer?
Quote from: Harvy on October 13, 2010, 10:02:57 PM
Thanks guys......
Depends on what the top end sounds like, I think.  IIRC, some of them had problems.
16" front wheel, so you have that same tire limitations as early FJ's, but the one I had was a sweet ride, with FJ like ergos.
But I wanted an FJ, and couldn't keep both.
Nancy's SO has more Honda V-Four experience than I do... he currently has 2 or 3 of them.
Yep, thanks Randy...... now that I know what it is I have been doing a bit of reading.......sounds to me like they were a bit weak in the oil supply to the top end, and many went back to the dealers for a mod to fix the problem.
I would like to get a V4 but this may not be such a good choice.
Thanks for the replies all.
Quote from: Harvy on October 13, 2010, 11:44:01 PM
Harvy-
You want a V4?  Splurge man, go and buy yourself a shiny new Aprillia RSV4 (and let me ride it).  :)
If'n I were looking for a Honda V4 to play with on the cheap, it would be one of the VFR gear drive models.
rlucas
Wheels are correct, at least for an '85 (which is all I could find a relevant shot of).
The V4s, at least the larger ones, had top-end lubrication problems that resulted in pitted camshaft lobes. Dunno if that applied to smaller-displacement engines or not. Apparently, the carbs are a bitch to remove as well.
It appears that the seller has the VIN wrong. According to everything I could find, it should be a 17-digit number with the first digit indicating the country of origin. The number given starts with what would appear to be a model code (RC16). That code would indicate a CX650 Turbo...which this bike definitely ain't
-Rossi-
Speaking of cheap V4's, I saw this the other day.  It's likely sold or a scam, bit it peaked an interest in me that my 'I have too many bikes already' self crushed....
http://philadelphia.craigslist.org/mcy/2001879083.html
Quote from: Dan Filetti on October 14, 2010, 11:09:39 AM
If it's too good to be true...       :nea:
rlucas
Feh...ain't no such thing as "too many bikes". There's just "not enough room" and "not enough time". Gettin' divorced went a long way toward clearing up the "space" issue...being unemployed covered the lack-of-time-thing.  :negative:
-Rossi-
Yes Rossi....... I found the same thing with regard to the VIN, which is what initially had me confused........all I could find was CX500 for RC16, and I knew it wasn't one of them. I rang him and he said it was a V-twin....which confused me even more.
I eventually figured it must be a VF700F, as that was the only Honda I could find with those wheels and that fuel selector on the left side of the tank.
Quote from: Dan Filetti on October 14, 2010, 08:08:08 AM
Harvy-
Dan, what a good idea........not only can you ride it.......you can also pay for it......... :rofl2: :sarcastic: :sarcastic:
