Replacement oil cooler
Started by SILVERGOAT, September 24, 2010, 11:54:49 AM
SILVERGOAT
  Could anyone give me an idea whats an upgrage to a stock oil cooler. Has anyone used an Earl's and whats needed to do an install. Thanks. Jeff.
It's easier to beg forgivness than ask for permission
i have a setrab 10 row oil cooler on my bike.... dropped the oil temps 40 degrees
everything you need to know right here.....
http://www.fjowners.com/index.php?topic=676.0
ccsct203
This is what I went with.
some say it's too large
but keeps the motor real cool
wheels
now thats an oil cooler. what did that set you back?
ccsct203
wheels
thats agood price  i was thinking a couple of hundred dollars at least
SILVERGOAT
  Thanks for the suggestions. Starting a winter to do list.
ccsct203
I change my oil yesterday and I was still able to get the exhaust on and off without having to remove the cooler.
I have to turn the cooler with the fittings on the top to avoid draining the oil out of it when the motor is turned off.
it makes it had to judge oil level with the extra volume it holds
wakdady
Quote from: ccsct203 on September 25, 2010, 06:08:00 AM
that is a sweet oil cooler! Where'd you get it?
ccsct203
ebay
i'll measure it and get back on the size
i cut angle aluminum and covered the side mounting
I still get air over the top to the head
it is no taller then the stock cooler only lower
width is about the same and I use the oem mount points
