more power mister sulo...
Started by conordylan1, September 11, 2010, 05:08:20 PM
conordylan1
i dont know who came up with every cloud has a silver lining, but i think it applies now. i recently posted about a busted crankcase :bad:but thats been sorted by a friend with a tig welder. Now seeing as my engine is completely stripped and my insurance provider has just informed me im not insured till 6/2011 [new government ruling in ireland]  :diablo: I really think its time for a bit of tuning. ive got the dynojet stage 1/3 kit already e4117.001 europe ready to fit, k+n and stock airbox, stock 4 into 2 with kerker race slip ons, now can i run the stage 3 succsesfully with the 20 1/2" holes dynojet recomend or is there a better alternative. Id really like to know how far to slot the ignition pick up bracket to get the best result, ive also got a friend with a machine shop and any advice on cam angles and duration and gas flowing would be appreciated. basicly any advice you can give me would be brilliant............ ive got a neighbour with a 929 blade and he gets on my tits.. :negative:
Why does it always happen to me..
WestOzFJ
Re: the ignition pick up plate mod:
I just the spare one I have off the engine to make this same mod myself....
The Pitch Circle Diameter of the 2 mounting holes in the plate measures 92.1mm. This makes the PC Circumference 289.46mm OR .804mm per 1 degree of crank  rotation. So, if you want a 5 degree plate that's a 4.02 mm shift at that PCD.
The crank/rotor spins anti-clockwise as viewed from the left side (same direction as the rear wheel), so the pick up plate needs to move clockwise to advance....
conordylan1
Quote from: WestOzFJ on September 12, 2010, 01:12:09 AM
thanks pal youve been a real help  :good2:
If you use the shadow left in the gold plating by the washer of the bolt(s) and slot to that edge it will garner 6 degrees. That is the quick and easy way to reference how far to grind that I use.
conordylan1
cheers guys , gettin real hard to source good info over here, this sites pure gold  :good: :good: :good:
