Front brake master cylinder
Started by barrelhead, July 08, 2010, 12:17:23 PM
barrelhead
HI ALL
Ive just joined the club , what a great site, i just got a fj 1100, so ive bought 3cv forks and blue spot brakes from a r1 , my question is should i change the master cylinder, if so any ideas??? without to much mod. , i keep you posted on my project , iam hooked.... looks like the bed in the shed for a while . cheers all , o iam in uk
Faster Faster!!! until the thrill of speed, overcomes the fear of death!!!
the fan
Howdy. Its a good idea to go with one of the several 14mm master cylinders available. Recently a few of us have tried out the newer radial masters with great results. On my YZF600 race bike I run a 2009 R1 master with 2002 R6 'blue dot' calipers braided lined. My brakes are amazing with this set up. Previously I ran the blue dots with an R6 14mm master.
SILVERGOAT
I use an '05 FZ1 front brake master cylinder, steel braided lines and calipers on my 89 with a YZF600 front wheel and 300mm EBC front rotors that I like a lot. The only mod I had to do was grind a small notch in the front of the right handle bar to allow the brake light switch to clear to allow the master cylinder to rotate forward enough for a comfortable lever angle. You can not see the notch after the install is done.
It's easier to beg forgivness than ask for permission
