Weird and potentially stupid question regarding calipers...
Started by Jay, January 03, 2026, 01:32:24 PM
Jay
Hi Guys.
As succinctly as possible;
My'89 1200, has been standing for more than 10 years, in the process of stripping it, to rebuild it.
Have taken off all the calipers to sort them, just wondered...
I know I can blow air through the hole with a compressor nozzle to hopefully pop the stubburn pistons out...but my gun doesnt have a rubber nozzle, so all I have to make the seal air-tight is a crappy old rag... it's not really working.
Do you know if it's possible to screw an M10 compressor quick-release adapter into the space usually housing the bango bolt? Or is the thread pitch different?
TIA gang.
'89 Yamaha FJ1200
'89 Honda CBR1000F
'96 Honda XR250R
'96 Honda XRV750
'03 Suzuki LTZ400
The thread pitch on the FJ banjos (all of them) is M10 x 1.25.
When I can't use air...I have a neat little tool made by Motion Pro that clamps the ID of the pistons for extraction.
https://www.revzilla.com/motorcycle/motion-pro-brake-caliper-piston-tool
Jay
Quote from: Pat Conlon on January 03, 2026, 02:25:47 PMThe thread pitch on the FJ banjos (all of them) is M10 x 1.25.
Hello again, Pat!
Ah right, I've seen these things before, they do actually work then yeah?
Have you ever had to use it on a REALLY stubborn piston?
thanks
'89 Yamaha FJ1200
'89 Honda CBR1000F
'96 Honda XR250R
'96 Honda XRV750
'03 Suzuki LTZ400
No, that tool is not for stubborn pistons.
For a stubborn piston that I can't get out with air, I use hydraulic force.
I reconnect the caliper to the brake line, then with a 1/4" plate I clamp the opposite pistons to prevent them from moving then pump up the master and use the pressure of the system to move the stubborn critter.
Waiex191
Bryan
1981 Suzuki GN400
Poplar Grove, IL
86FJNJ
+1 on the gold dot or blue dot R1 calipers!
I'm rebuilding calipers now on my Honda I sprayed on blaster on the inside and let it soak for a few days. Then clamped it in my bench vise and heated it with a heat gun then got channel lock pliers and twisted it out slowly no problem.
Yea, I agree, the R1 monoblock calipers are a great upgrade for your '89.
Unless I'm doing a concourse restoration with all correct oem parts, if I had a stuck piston in my front oem FJ caliper I wouldn't even bother fussing with it and go directly to the R1 calipers.
Except the Rear caliper, yep, gotta free that piston.
