Engine oil weight question
Started by 86FJNJ, August 28, 2025, 09:13:50 PM
86FJNJ
Been running 20w-50 Valvoline VR-1 conventional all summer in the hot temps. Here in NJ the temps are starting to get colder, 50f when I leave for work in the morning and 70f mid day. I plan to ride into the fall when temps are colder, can I still run 20w-50 in cooler weather or should I switch to 10w-40 at some point?
On my 89 I have had only one issue with oil weight. When the temps are cold my starter clutch has a hard time engaging.
86FJNJ
I run a 10w-40, I would go 20w-50 year round.
86FJNJ
Thanks I just want to make sure I'm not doing any harm running too heavy of an oil when it's cold (under 50f). I see Motul 7100 comes in 10-50 or 10-40 or even 5-40 but it's pretty expensive at nearly $20 per liter.
Oh boy, an oil thread....its been a few years since we've had one....
When you ride your bike to work, how long of a ride is it?
Is there enough time for your oil to heat up to at least 180°?
Consider putting a cover over your oil cooler for cold temps.
Personally I would use a 10W-40 or even a 10w-30 ester stock synthetic oil for cold weather riding....
.....but then again, I'm from Arizona so I know diddly squat about cold weather riding. (Fuck that shit)
Aviation Fred from Kansas and Giant Killer (Dan) from Wisconsin have forgotten more about cold weather riding than I will ever know.
My cold weather theory: There is a reason the Automobile was invented....
MarioR
 I like this one "My cold weather theory: There is a reason the Automobile was invented...." :morning1:
It does not matter how slowly I go as long as I do not stop.
86FJNJ
Sorry for a newbie oil thread. Ride to work is 25 minutes.
86FJNJ
Anything wrong with me doing a 50/50 mix of Valvoline VR1 10w-30 and 20w-50 to get a 15w-40 for cold weather?
I know the VR1 oil is good for engines with Flat tappet cams and some of the other 10w-40 motorcycle oils I'm looking at don't seem to have the same stated protection for those style engines. Unfortunately VR1 doesn't make a 10w-40
Since Pat was so kind in giving me a reference. I will weigh in. As stated,I live in Kansas and ride year round. The original oil weight recommended by Yamaha was Yamalube 20w40. 40 year later, this weight is hard to find.
In every motorcycle that I own, except the Moto Morini (due to it being on warranty), I use Shell Rotella T6 15w40 year round. It is an inexpensive full synthetic that is JASO MA/MA2 certified. In the 10 years or so of using this oil, I have never experienced clutch slippage due to the oil, or any engine related issues due to oil. I hope this is helpful.
Quote from: 86FJNJ on August 28, 2025, 09:13:50 PMBeen running 20w-50 Valvoline VR-1 conventional all summer in the hot temps. Here in NJ the temps are starting to get colder, 50f when I leave for work in the morning and 70f mid day. I plan to ride into the fall when temps are colder, can I still run 20w-50 in cooler weather or should I switch to 10w-40 at some point?
I've used 20w50 mineral oil in all weathers and temperatures, with no issues in 107,000 miles on my main FJ.
I ride all year round but not usually deliberately for fun when it's below 0c or 32f and I never worry about my oil. Just change it and the filter regularly and all will be well.
Quote from: aviationfred on August 29, 2025, 03:53:41 PMSince Pat was so kind in giving me a reference. I will weigh in. As stated,I live in Kansas and ride year round. The original oil weight recommended by Yamaha was Yamalube 20w40. 40 year later, this weight is hard to find.
Same here Rotella t6
Edouard
I pour 10w40 into my FJ, but now I bought 15w50. In spring and autumn I start my bike when the temperature is slightly above 0 Celsius. There were no problems with oil ..40, let's see what happens with more viscous. But in summer, when the temperature is above 20 degrees, definitely ..50. Ideally, pour in thinner oil in September, and change to thicker oil at the end of spring))
1991 Yamaha FJ1200A
1992 Kawasaki KDX 200 SR/R
1995 Yamaha Mint
2002 Honda Gyro UP
86FJNJ
I'll probably change my oil before winter using my normal Valvoline VR1 20W-50 but with the cold temps comming I'll exchange 1 quart with VR1 10w-30 which should net me a 17.5w-45 for winter  :biggrin:
I also got some Rislone zinc additive recently so I've put some of that in the crank case to bump up the zinc content.
Report back when your clutch starts slipping from the zinc additive.
