Gravity Fed to Fuel Pump Conversion Instructions
Started by 86FJNJ, June 23, 2025, 01:51:44 PM
86FJNJ
Converted my gravity fed 1986 FJ1200 to have a fuel pump with the help of Pat, the RPM team and this forum . Nearly 300 problem free miles on it at this point. THANK YOU!
If anyone is interested in doing the conversion, the attached document may help you. Special thanks again to Pat for his contribution on putting this together.
Due to file size I'm attaching the document in two parts. I'll make a reply comment with part 2.
1986 FJ1200 converted to Fuel Pump
86FJNJ
Well done Eric! Your work will help others.
After questions and comments are made here, I will save this over in our Modifications Files section.
Thanks Eric!
JohnnyTheCraneGuy
I personally think you did an amazing job at presenting this project in a easy yet informative format that really stays on track man, Bravo sir!  :hi:
2003 XVS650
1990 FJ1200 Fiona
1986 FJ1200 (Parts Bike)
86FJNJ
