Parts For Sale
Started by Modo, June 04, 2025, 10:08:03 AM
Modo
Thinning out the accumulation. Actual shipping to be added to price.
Coming from Asheville, NC.
Stock subframe; straight, no damage. $50
FZR1000 rear wheel with sprocket hub. Modified to fit the stock FJ swingarm. Ran this with 180 tires for many years until switch to FZ1 bits. Dampers look good but they're old, so...  $100
Tail section complete $40 (I think I have two of these)
RH and LH footpeg(s) sub bracket (the aluminum casting thing). 2 sets
$25 a set
Side panels w/filler panels - both sides. Tabs and pegs intact. $20
Bar ends $5
40T rear sprockets. Good condition. Make offer
Can sends pics if interested.
What year are the side panels. Not scuffed? And is the wheel a direct bolt in spacers and everything included. Used stock brake ect.
Modo
The panels are from a '92 and are in pretty good shape. Painted for my '87 and are a direct fit up.
The wheel would include all spacers. Been a while, but I think I used the FZR rotor (can be included but is worn a bit), stock sprocket, and I'll have to look at some pics to see what caliper/bracket I used. I pretty sure I have all of it and would include everything.
Another variable: The front sprocket. I think it has to be offset outboard a little (?). This would take a little research, but nothing was terribly difficult.
Modo
Just checked and I have all spacers and axle. Found the caliper mount and the torque arm. As for the caliper, I don't remember sourcing a different one, so I think I used the original. The FZR rotor is 10.5" in diameter, so take a look at yours and see if it might work.
Modo
Oh, and the stock rotor will bolt to this wheel as well.
JohnnyTheCraneGuy
Yo I would love to grab those panels, and the caliper mount. Will send you a PM later today once I am home if that works.
2003 XVS650 (Sold)
1990 FJ1200 Fiona
1986 FJ1200 (Parts Bike)
Modo
No problem, but I need to hear back from Giantkiller first, as he has asked about them.
The caliper bracket has been modified at the axle hole. This one is .855" thick; stock is about 1". It is this way to work with the FZR wheel.
If Giantkiller takes the wheel, this will go with it too.
Will post up as soon as I know.
I would love to take the wheel from you. Will pm you
Modo
Sounds good.
So, Crane Guy, the caliper bracket goes with the wheel assy. Sorry.
The panels are yours if you want them though.
Modo
Wheel assy and caliper bracket sold.
Modo
Bracket not braket. Doh.
