Proper carb setup+unplugged cable
Started by GeeseH, May 06, 2025, 02:34:41 PM
GeeseH
Hello, this is my first time posting here so I don't know what the proper format for asking questions is but I've had a 1990 Fj since august of last year and now I am getting it ready for the riding season but there are a few things on the bike that have puzzled me. The first thing I noticed is that the carb setup seems to be missing hoses/has hoses in the wrong place. there are a few white plastic nozzles in between some of the carbs that have no hoses and there is a hose that goes from the top of one carb to another, which I haven't seen in the manual or on any other carbs for this bike or others. I also noticed that there is no inline fuel filter which the manual says there should be. It would help if anyone could post a picture or tell me what is supposed to be connected to the carb and what isn't and where hoses should be and where they shouldn't. I also noticed that there is a orange and black wire that has a clear/white termination that is not connected to anything and I can't seem to find where it connects to. I have attached some pictures for both issues and I appreciate any help I can get.
86FJNJ
Was the bike running when you got it or was it sitting and you are trying to get it running?
1986 FJ1200 converted to Fuel Pump
GeeseH
It was running and I rode it from August to December, in which I had a stuck float needle which caused a gas leak so it sat outside in the winter (terrible I know but I learned my lesson). I have a video of it running post winter that I can share, the stuck float needle fixed itself but it still has an erratic idle so I will take the carbs apart and go through them. The carbs are synced as tested with a vacuum gauge so I think they just need a good cleaning.
RPM - Robert
Those hose from carb to carb was for a CA emissions system and charcoal cannisters, which someone has removed. Most people put vacuum caps on them.
That plug sounds like it is just a keyed 12v source from the removal of the solenoid for the emissions system.
The white tees in between 1/2 & 3/4 are the overflow hoses, a smaller hose on each carb body that is a vent, an you should have a single fuel inlet between 2/3.
