89 FJ1200 Air Filter missing retaining clips
Started by freeride, February 09, 2025, 04:46:38 PM
freeride
Hi All,
First post, but have found a lot of helpful information here! Last Summer I purchased an 89 FJ1200 with custom sidecar rig. The bike is pretty awesome, about 48k mi. with a top end rebuild and has been loved by prior owners.
I have and continue to struggle with the carbs. They were professionally synced and tuned when I bought the bike and shortly after started leaking fuel. That led my mechanic to replace some rubber rings on the fuel rail, which stopped the leaking. Now the #3 carb bowl is spewing fuel out the overflow hose. My guy wants to dig into it again and verify it's not also the fuel rail, but I'm at the point of thinking that replacing the carb may be better to baseline things and start fresh.
When taking a look at my air filter the other day I found it just laying loosely in the air box. Looking at the workshop manual it notes "retaining clips" for the air filter to be held in place. I don't have a part number and we definitely don't have the clips. I am struggling to find them anywhere for sale.
That said, I have seen many people apparently remove the airbox entirely and use a Uni filter - is this the better way to go? Any other recommendations?  Thank you!
JohnnyTheCraneGuy
Me personally, I would keep the carbs you have now and just finish rebuilding them. There's really not much too these Mikuni's IMO. Especially since yours is stock. Ultrasonic is honestly the best thing you can do when cleaning or rebuilding them. Carb cleaner and guitar string for the jets will do wonders!
 But aside from that I would start at "Float Needle Valves" but YMMV
Those are generally rubber pointed/tipped and they control fuel from entering the float bowl and when the go bad they cause fuel to dump out into the overflow.
While you're/mechanic is in there it would be a good idea to replace the bowl gaskets as well.
As for the Uni Filter Pods I do 100% recommend it, although it does involve much more than removing the airbox and changing the filter. You'd have to re jet the carbs, adjust your needles height, adjust your PMS screws, and you're going to wanna upgrade your exhaust as well to balance everything out. I'm sure it'd be a nice project but there's a lot of great info and even better people on here to help out if you decide to go through with it!
2003 XVS650
1990 FJ1200 Fiona
1986 FJ1200 (Parts Bike)
Also the float needle valves have an o-ring around them that is prone to drying out and offering fuel a pathway around the float needle and into the float bowl to flood it.
Did the bike set up for any time before you bought it?  Does it have a fuel filter?  It might also be a simple as some trash keeping the #3 float valve from sealing.
First time I've seen blue spots on a side car rig!  Nice setup  :good:
Added: I've never owned an FJ with an airbox (never even seen one!) - always liked the uni pods.   RPMracingca.com carries them and much more!  Plus Robert and Randy are a wealth of knowledge and experience with these bikes and engines.
Paul.1478
send them to RPM. I did it 2 times (not due to anything they did, i let it set too long 2 times). the come back PERFECT. I tried to take care of them myself, but sent them in. Worth every penny.
2006 GL1800
2022 Ducati V2
1976 RD400
1993 FJ 1200 ABS
Tibsy
Quote from: freeride on February 09, 2025, 04:46:38 PMWhen taking a look at my air filter the other day I found it just laying loosely in the air box. Looking at the workshop manual it notes "retaining clips" for the air filter to be held in place. I don't have a part number and we definitely don't have the clips. I am struggling to find them anywhere for sale.
There are 2 "wedge "shaped pieces of plastic which hold the air filter in place- some people make there own using wooden clothes pegs!
freeride
Thanks for all the replies here. This is still in progress but parts are here. Just got a new carb from Randy since we've had so many issues with the existing one, and he set it up for a sidecar and the Uni Filters. We're going to do the timing advance mod too and then we'll see how she runs.
Stock exhaust for now, but also did wonder about upgrading the exhaust.  Right now this is less about performance and trying to get some reliability out of it. :)
plus one on the pods. Makes it easy to attach and service. Best of all you can fit your arm right through the bike and shake hands with your helper.
freeride
Quote from: andyoutandabout on March 16, 2025, 02:21:04 PMplus one on the pods. Makes it easy to attach and service. Best of all you can fit your arm right through the bike and shake hands with your helper.
Ha! Yeah, that stock airbox is huge and the filter was kinda silly without the retaining clips. Glad to have it out of there.
JohnnyTheCraneGuy
Crazy you have to drop the tail to get the airbox out!
2003 XVS650
1990 FJ1200 Fiona
freeride
Got the new carbs and intakes installed today and she runs wayyyy smoother and sounds better. Took her out for a quick spin down the street and it's like another bike - pulls hard and linear power throughout the rev range.
Now I have a sticking throttle cable...throttle doesn't snap back to idle (not even close). I took it apart and lubed it which didn't help at all. Thinking I will replace the throttle cables and not mess around.
