84/85 gas cap bluprint
Started by maverick9611, December 31, 2024, 08:42:18 AM
maverick9611
i made the sad mistake of taking apart my 85 cap cap, didn't realize the gasket is really a oil seal. now, can't get it back together. i have got it all together a couple of times but the key will not turn. it's a true finger fumble
85 fj1100
maverick9611
I got it back together but the fingers are flared out too much and I can't even get into the filler neck so obviously this is wrong
85 fj1100
If you turn the key will the fingers retract far enough to close it?
maverick9611
Quote from: fj1289 on December 31, 2024, 10:35:18 AMIf you turn the key will the fingers retract far enough to close it?
no even close. the fingers have to sit like this
85 fj1100
maverick9611
with two fingers being straight that means a tumble mechanism and the little springs have to be straight in a line also i presume. you can see spring intentions on the fingers that are inside the housing so I'm pretty sure this is correct. The problem is though I'm messing those springs up big time
85 fj1100
maverick9611
I cannot find one print even the service manual showing any kind of breakdown of the gas cap assembly does anybody have a print?
85 fj1100
maverick9611
I started looking at old Yamaha gas caps on eBay and I noticed all the fingers were in quite a bit so I looked at mine and noticed I can mount the finger side-by-side
85 fj1100
maverick9611
85 fj1100
Sweet!  Glad you got it sorted - and shared it on here!
axiom-r
I never thought I would need this info but as it turns out - I DO!!    I am trying to swap the key mechanism from one 85' Cap to a newer better condition cap.
I disassembled the original and all the parts fell out - so this reassembly help is greatly needed.  However, I am still stuck in trying to remove the key tumbler/barrel assembly itself.  It appears to be located with an o-ring on the inside after all the "finger assembly" is off.
Can the key barrel be easily removed?  Whats the trick? I don't want to break it and end up chasing tiny parts.
Cheers!
tim
axiom-r
Found a detailed disassembly video....
