vibrations
Started by weymouth399, June 06, 2010, 10:15:23 AM
weymouth399
My 86 has a bad vibration in the lower revs, seems to go away after 4500 rpm.
My buddy's 89 does it also, but his 1100 don't. There all recently tuned.
just wondering if any one else has a similar problem, and how to remedy it.
It's very annoying and makes my hands go to sleep after a couple hundred miles
Thanks Bob
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
jvb_ca
A good carb sync will eliminate alot of vibes. Motor mounts...on rubber mounted engines they can seize and create vibrations, but ours(86's) don't have that type of mount. I had a motor mount bolt go missing a while back, and found that after replacing it and torquing down the rest of the mounts I have more vibrations then before. :pardon: go figure....
Not much help but....
Cheers..Jake
Cheers...Jake
86FJ1200
Ontario
86 isn't rubber mounted so much.
Start with a carb synch.  Actually, start by checking yer valve lash, probably time anyhow isn't it?  If it's specific to low revs and happens in any gear, you're talking motor vibes rather than wheel balance or the like.
