Clutch Master Cylinder Sight Glass
Started by Chainlube, March 04, 2024, 02:44:12 PM
Chainlube
Has anyone found a suitable replacement sight glass for a 1984 FJ1100 clutch master cylinder?
Thanks.
1984 FJ 1100
2024 XSR 900
2015 V7 Racer
1978 KZ 200
petetb154
Im not sure about the 1984 model but I would assume it's the same as newer ones. In my experience, this 18mm replacement lens will work in most Japanese master cylinders https://www.rockymountainatvmc.com/parts/tusk-replacement-brake-master-cylinder-sight-glass-p
They are cheap, just $4.99. If the diameter of the glass is approximately 18mm, that should work.
Brian Peterson
1987 FJ1200
