Has anyone fitted an FZR1000 EXUP Swingarm?
Started by joebloggs, September 13, 2023, 04:13:32 PM
joebloggs
I have a EXUP arm attached to my thundercat, that will be broken, I've already used the entire front end and the rear wheel etc so it would be a sin not to also fit the complete arm on the FJ, only thing is, I can see no info anywhere (anywhere I've looked)
I offered the Thundercat swingarm up and there's space either side, so no other machining is required there and the sprocket face had 6mm milled off to allow the sprocket to sit further in, so should pretty much bolt in with a few spacers to centralise the wheel.
So, has it been done and did it work?
One thing wouldn't surprise me is if the arm was to wide near the footrest hangers, not a problem for me as I finally found a neat way of bolting on the Harris rearsets and they could be spaced further apart if necessary, but could have been a show stopper for some.
1989 3CV
