FJ1200 not starting when all spark plug caps are connected
Started by gpspl, August 15, 2023, 10:12:40 AM
gpspl
Hi,
I have a strange problem. My bike died 5h ago after 1h drive just when I was parking on the beach. It run ed great for 100km and died. I found out that there is a fuel flow to carbs.
Here is a strange part. When I disconect any s0arkplug cap from sparkplug it imidierly starts and iddle fine-rough but it idles. When I connect it back revs goes up a bit but it does not idle, dies ant won't start until I disconect a spark plug cap.
Proud owner of a little cursed FJ1200 3CY 1989
gpspl
Sorry for all mistakes. When I was writing original post I was standing in the middle of nowhere trying to fix my bike in full sun for past 3h.
It appears that there is no spark when all sparkplug caps are connected to all sparkplugs. When I disconect one (doesn't matter which one tried from 1 to 4 bike starts immediately. I think it may be bad coils that heated too much from riding and failed. Am I right? How to test them - my bike is fj1200 1989 3cv.
That is a strange problem for me, maybe others will have better input.
gpspl
Bike and coils cooled overnight and now it started/there is a spark with all sparkplugs connected. So it is related to heat I guess but what :)?
Old Rider
I can bee coils .they can stop working when hot .Check if there is any cracks on the underside of the coils
if it is throw it in the bin. I  checked the coils on my kawa some days ago and took some picks .You can test the coils
on the fj the same way.Dont look at the readings i got on the picks.I posted the specs for the FJ coils from yamaha
manual in pic 4. If testing the ht wires with the sparkplugcaps on you sholuld retrackt 20 ohm on the reading  because of the sparkplugcaps.I think the fj has 10 ohm resistance caps
gpspl
On warm engine primary was 4.1 and 4.0 ohms, and now when it cooled its 2.4 and 2.2 ohm. Secondary is 13.5k on both, caps reads 10k
Old Rider
Quote from: gpspl on August 16, 2023, 06:11:38 AM
Ok the manual says to mesure them when 20 degree celcius . On the secondary it shuld be about 32K ohm when measuring with the 10k plugcaps fitted onto the HT wires. Check how much voltage reaching up to the coils .I have posted a pick how to measure .in the pick i did it wrong i found that out later. Have not tested the coils the right way later because the bike runs well.
but i have tried to explain the right way  to measure in the textbox on the picture. And try also to check underside of the coils for cracks if cracked they are toast.
gpspl
gpspl
Still looking for cause of no spark. Any idea what else I can test? Is there a test for ignition module?
Old Rider
You can test the pickupcoils like described in the picture from manual above. If i remember right you will not get spark if the sidestand switch
not working, same with the clutch switch and also maybe the neutralswitch. Check the 15A fuse to.You can check the killswitch to.I dont have more picks from the manual now. The clutch switch you can test by making a little jumpwire and take off the connectors at the handlebar
under the clutchreservoir and jump them .you can test that too on the sidestand switch connector it is placed under left sidecover and i think it is the green connector .It is not the red connector that is for alternator and usalli it melts .You can check if it is melted.I think that the voltage to your coils is to low but not sure i cant check that now because i dont have the manual here. You can check the sparkplug gap it should me 08-09mm .Check that plugs are clean and how does the spark look if it is yellow it is weak an may not fire the gas if it is strong and blue it is good. If you have checked all this and still dont get spark i have to throw in the towel  (popcorn)
gpspl
Checked and pickup is in spec. I just don't understand why it has no spark with all sparkplugs connected and the moment I unplug one it starts first crank, then when I connect sparkplug cap back it runs on all 4 but dies when rpm goes below 4k. Battery is new but just to be sure I connected battery from my other bike and still same. And why it happened suddenly like I rode for the past 5 days average 55 miles a day and died when parking :)
See if you can isolate the problem to just one coil. (The chances of both coils going bad at the same time are nil.)
Left coil powers cylinders 1 and 4
Right coil powers 2 and 3
Take off the plug cap on either cylinder 1 or 2 see if the same thing happens.
gpspl
I did that, I'm fact that's how I returned home yesterday by unplugging 1 to 4 sparkplug every 25km.
It doesn't matter which sparkplug I disconect 1 to 4 it just starts. I also unscrewed cylinder 1 sparkplug and grounded it with wire there was no spark but the moment I unplug cylinder 3 sparkplug spark appeared on that first plug.
It's so unrealistic that I'm thinking this bike is cursed :)
So, removing either #1 or #4 causes the same thing to happen.
This does not happen with either #2 or #3, correct?
T Legg
He stated unplugging any of the four leads would allow it to spark again. Very strange for sure.
   I don't know why unplugging one would restore the spark. You might check that your ground connections are good. That connection would be common to both coils.
            There is a test for the ignitor box in the electrical files section https://fjowners.com/index.php?topic=19679.0
      It describes how to trigger the box to cause each individual coil to fire. I've used the method on my fj 1100's. I think it might work on later model ignitor boxes but I haven't had an opportunity to try it. The wires and colors are different on later models but the two wire connector that goes to the trigger coils is easy to identify.
T Legg
