crank seal
Started by Travis398, May 27, 2010, 04:49:06 PM
Travis398
alright i have to ask, has anyone had any luck changing a crank seal (on a FJ) without splitting the case?  :pardon:
inquiring minds want to know  :yes:
Quote from: Travis398 on May 27, 2010, 04:49:06 PM
Travis,
Changing the seal is the easy part, getting the bolt off of the rotor is the hardest part. The replacement seal slips right in after you get the old one out.
Right Jake?
jvb_ca
Just replaced the crankseal last weekend. Like Randy said, the hardest part was getting the rotor bolt off. I had to use an air gun. Removed the rotor and  both pickups(move off to the side) and with small scewdriver and dental pics, I was able to pull the old seal out. Used the old seal as a driver to install new seal. Was actually quite easy. The replacement seal is a bit different than the original seal. It does not have the lip on it, which allows replacing seal without splitting cases. TRoy has a good pic of the two different seals on the yahoo group site. Do a search for crankseals.
Picked up the seal from Randy, and a few tips. Thanks again Randy.. :good2:
Oh ya..drain oil before removing old seal.
Cheers...Jake
Cheers...Jake
86FJ1200
Ontario
Travis398
Thanks Randy and Jake,   :yahoo:
you guys have lifted a huge weight off my shoulders.
Travis398
i think i found my crank seal leak.
:ireful:
i think the oil was running down the pick-up wires into the ignition cover
Travis,
It also looks like there is two o-rings in the groove and they also look blue which I believe is the smaller o-ring. There are 2-3 different o-rings & groove depths. If they have the small o-ring(s) in the large o-ring groove it wont seal. The missing flange should not really create an issue as the o-ring seals around the case O.D. & the alt inner I.D.
Some epoxy to repair the flange to ensure the o-ring doesn't slip out of the missing section would be cheap insurance. But since the o-ring is forced to the rear of the groove during installation it should never get to the front or missing section. You need to measure the groove width as I believe the two bolt alternators use the larger/thicker o-ring which is black.
I can get you a part number next week and I might have one of each new and in stock. If not I should have a good used one lying around.
Didn't you start the "Previous Owner" thread a while back as well...?
Let me know,
weymouth399
The problem is he knows one of them dam legends drivers. :dash1:
That has WAYYY to many parts in stock.  :crazy: :wacko1:.
Minus crank, rods, and cases.
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
Travis398
Quote from: racerrad8 on June 12, 2010, 01:26:36 PM
Travis,
Let me know,
actually there is just one o-ring, i took several pics of this but none of them came out very clear.
I'm sure you probably have seen the broken alternator bolt in the case, on the two bolt alternators?
well that is what i found after i bought the bike and the other bolt was loose enough for the alternator to push it self out a little.
i may have changed the o-ring (not knowing there is different ones) got the broken bolt out and bolted it
back together, i think it was okay for a while. But lately it seems to be leaking more and more oil.
Bob loaned me an alternator for now so I still have a ride, but would like to fix this one if i can.
the alternator seal couldn't really leak that much oil could it?
