FJowners.com
March 26, 2023, 02:40:17 AM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
News:            Enjoy your FJ
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: Press start, 1 click. then nothing.  (Read 389 times)
Loukiii
Jr. Member
Offline Offline
1986 FJ1200
« on: December 30, 2022, 10:07:49 AM »
I turn on the key, neutral light comes on. Pull choke, press start, engine cranked and then went dead. No lights, no clock, nothing. Checked fuses all good.
Turn on key neutral light comes on, 1 click and dead. engine did not turn over. no lights no clock nothing. turned key off clock is on. turn key on no neutral light clock goes out.
Turn on kill switch turn off kill switch, turn key, neutral light is back. press start. 1 click dead. same as above.
I saw the thread about cleaning the kill switch but I figured I would put this up here before I start messing with stuff.  I will clean the kill switch while I wait for replies.
Logged
T Legg
Hero Member
Offline Offline
Gender: Male
84 FJ1100 x 2
« Reply #1 on: December 30, 2022, 11:07:21 AM »
Try cleaning your battery terminals. It sounds a lot like a loose or dirty ground connection.
Logged
T Legg
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #2 on: December 30, 2022, 12:47:50 PM »
Dying battery, now dead.
Logged
2) Don’t store your FJ with E10 fuel https://tinyurl.com/3cjrfct5
4) Important items for the ‘84-87 FJ’s:
Urx
Full Member
Offline Offline
1990 uk 3CV in black(blue) and gold, 32k miles
« Reply #3 on: December 30, 2022, 04:22:58 PM »
My guess is a broken or shorted  plate(s) in the battery so that you may have enough to give near 12v and light your neutral bulb but not enough to crank the motor.
Try another battery or jumping from a known good battery.
Logged
Stainless lines
Blue spot calipers but std m/cyl (so far)
Ebc prolite front discs
Ohlins remote adj rear shock
Remus 4:1
Still running original chain and sprockets from new (scotoilers really work)
Krauser k2s
Loukiii
Jr. Member
Offline Offline
1986 FJ1200
« Reply #4 on: December 31, 2022, 05:58:41 PM »
Weirdest thing I ever saw. I charge the battery, test with volt meter 12+ volts... try to start, click pop. Test battery 10 volts. Put battery on charger says fully charged in like a minute.
So I am getting a new battery. Hopefully that is all it is.
Logged
T Legg
Hero Member
Offline Offline
Gender: Male
84 FJ1100 x 2
« Reply #5 on: December 31, 2022, 06:30:20 PM »
That is a classic sign of a bad battery. Pat had it right on the money.
Logged
T Legg
Waiex191
Hero Member
Offline Offline
Gender: Male
« Reply #6 on: December 31, 2022, 08:23:25 PM »
Same thing on my son's V30 Magna.  Classic dead battery syndrome.  His bike charges too high and the battery was boiled down.  We added water and it sort of works - but a new battery is on the way.
Logged
Bryan
1981 Suzuki GN400
Poplar Grove, IL
Loukiii
Jr. Member
Offline Offline
1986 FJ1200
« Reply #7 on: January 01, 2023, 07:32:53 PM »
Yep. It was the battery. Thank goodness.
I have had low and dead batteries before but never that behaved like this.
Thanks for the help everyone.
Logged
balky1
Hero Member
Offline Offline
Gender: Male
« Reply #8 on: January 04, 2023, 04:34:02 AM »
Glad you solved it. Bad batteries manifest in weird ways on old bikes.
Logged
FJ 1100, 1985
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 :: SMF © 2006-2009, Simple Machines LLC
SMFAds for Free Forums
Valid XHTML 1.0! Valid CSS!
