What’s the nozzle for and why is there a jet in the crankshaft bearing?
Started by Marqus, November 20, 2022, 02:04:11 PM
Marqus
Hi,
Can anyone explain what the nozzle is for, that sits behind the generator and sometimes gets scratches from primary chain?
And why is there a bronze jet in the lower crankcase half???
There is an oil jet that directs oil onto the starter chain, is that what you're referring to?
https://fjowners.com/index.php?topic=19016.0
#23
RPM - Robert
Quote from: Marqus on November 20, 2022, 02:04:11 PM
Pat already covered the nozzle jet for the starter chain.
The oil "jet" is a restrictor Yamaha installed into the center main bearing journal. The reason I believe is that main bearing journal doesn't have any other function other than to lubricate the bearing, so it doesn't need as much oil as the other journals. Journals 2 & 4 provide the oil to the connecting rods. The right bearing sends oil to the cylinder head and the left bearing needs the additional oil to provide a more stable bearing surface to keep the crankshaft centered to control the ignition rotor movement.
