Petcock
Started by twood1972, October 10, 2022, 08:49:01 AM
twood1972
Good morning.
Wondering if someone can give me conformation as to if a 1984/85 fuel petcock does or doesn't fit a tank from a 1986 1200? I understand the electric reserve function wont work but I dont need that.
Thanks.
TIMOTHY
Yes, the 84/85 petcock fits the 86/87 tanks.
I'm kinda of an old fashioned guy, I think the electric reserves are stupid.
You've got a gas gauge, low fuel light and odometer....with these, if you run out of fuel, you deserve to walk.
Waiex191
I don't know if the '86 is the same as my '89, but I would assume so.  The electric reserve has nothing to do with the petcock.  It turns off the fuel pump.
Bryan
1981 Suzuki GN400
Poplar Grove, IL
Quote from: Waiex191 on October 10, 2022, 09:07:29 AM
Bryan, the vacuum petcocks on the 86/87 are different than the later '88+ fuel pump models.
Remember, no fuel pumps on the 86/87's so the petcocks have a built in solenoid that restricts fuel flow when triggered by the fuel level sensor in the tank.
petetb154
Quote from: Pat Conlon on October 10, 2022, 09:06:31 AM
+1. I 100% agree.
Brian Peterson
1987 FJ1200
twood1972
Thanks much. I was pretty sure I'd heard it would work but wanted confirmation.
TIMOTHY
Motofun
I never understood what was wrong with the old fashioned petcocks.  You know, the ones with reserve and a two height inlet inside the tank.  Run out of fuel on "run" and switch the petcock to reserve opening the lower tap in the tank and get another gallon or so....
'75 Honda CB400F
'85 Yamaha RZ350
'85 Yamaha FJ1100
'89 Yamaha FJ1200
'09 Yamaha 125 Zuma
'13 Suzuki GSXR 750 (track)
'14 Yamaha FZ-09
'23 Yamaha Tenere 7
Quote from: Motofun on October 11, 2022, 07:49:56 AM
Yes... simple and true, and none of this vacuum open and shut off shenanigans....just train yourself to reach down and shut off the petcock when you turn off your engine.
Alas, the good old days before we had motorcycles with plastic bodywork. .
