1985 Fj600 Wiring connections?
Started by Cbraun, August 11, 2022, 03:56:50 PM
Cbraun
I've had my bike apart since last fall tracing down wiring issues. the only reason i started that is because 2 out of 4 carbs went bad. The body's are worn out where the cv slides go. I'm to the point minus carbs and a new fuse block I can put the rest back together. Its been so long I cant remember how all these plugs go and what color goes to what or if I'm missing something. Does anyone have a photo or know what wire colors go where?
Any help is greatly appreciated.
85 FJ600
Hi Chris....see pages 194 and 195 for the color coded wiring schematic on your '85 FJ600
https://www.manualslib.com/manual/797416/Yamaha-Fj.html
Cbraun
That would be great, but its nearly impossible to make out the color designations for the wires, I'm running in 4k on a 32" screen and even zoomed in, just blocks of black pixels.
85 FJ600
Cbraun
Quote from: Cbraun on August 11, 2022, 03:56:50 PM
85 FJ600
Quote from: Cbraun on August 12, 2022, 08:28:31 AM
Ok, I see what you mean...
The FJ600 Haynes workshop manual is still available.  $16, not too bad
https://www.discoverbooks.com/Yamaha-FJ-FZ-XJ-amp-YX600-Radian-Owners-Work-p/1563921006.htm
Sorry I can't be more of a help....As far as I know, you are the only FJ600 member on this forum.
Cheers. Pat
RPM - Robert
I think JPaganel had/has one as well, but maybe it was someone else.
twood1972
TIMOTHY
twood1972
TIMOTHY
Quote from: RPM - Robert on August 12, 2022, 11:07:18 AM
I remember spotting an FJ600 when I stopped at the Tail of the Snake, near the Rock Store in the Santa Monica mountains. It was a Father Son ride. The son had the FJ. We had a few posts about it, then tragedy struck and the FJ had a catastrophic case failure. Then all went dark. Maybe it got put in the back of the garage for restoration later, when its one of the last 5 on the planet.
Old Rider
I had one back in 1985 and i remember it had some electrical issues .Often had to start it by doing a running start mostly after it had been washed or in rain weather.That was before i discovered that using a little wd-40 into the sparkboots and on ignition contacts etc often can helps with that problem .This is the only pic i have of it.Another time a member needed carbs for fj600 and i was sure i had one in the shed at my mothers house so i cold give it to him ,but after searching there i could not find it
now my mother is dead and the house sold so no way to find the carburetors now
