FJowners.com
June 08, 2023, 12:07:36 AM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
News: This forum is run by RPM and donations from members.
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: Bad start from a no start  (Read 378 times)
gumby302ho
Sr. Member
Offline Offline
Gender: Male
wine women an song, and a FJ !!!
« on: April 28, 2022, 10:07:36 PM »
 Well its the start of the season up here and my first real lick of trouble for my ITX has came up. I am going to trouble shoot tomorrow and clean up connections and check for power at the coils and ohm them out and whatever else the manual leads me but my question is parts. If it turns out I need coils or TCI modual where can I get them. Is there a good manufacture that makes good electrical components, is there still OEM or is ebay my only option. I just want to get the ball rolling. Insurance renewal is May 5th and they get pissy when you cancel. Hopefully its a bad connector or ground someplace fingers crossed. A woman in Pembroke last week has already died on a motorcycle, I did not get details but the roads are very sandy and have lots of bumps and heaves this time of year so one needs to be very careful.
Logged
Super Hero Member
Offline Offline
Gender: Male
« Reply #1 on: April 29, 2022, 04:48:58 AM »
Care is definitely required, especially on your first rides after a winter lay-off.
Bikes usually need a bit of attention to get them ready for the new season, and riders do too - skills go rusty, hazard perception deteriorates, senses are dulled, muscle memory takes time to kick in - once she's up and running properly, maybe take on a rider training session, just to bring your body/brain back up to "riding fitness". good2
Logged
gdfj12
Silver Contributor
Full Member
Offline Offline
1989 FJ1250 w/XJR bits & 1987 FJ1200 . .see sig.
« Reply #2 on: April 29, 2022, 07:47:14 AM »
Ebay is one source for spare parts. The first thing is to check all connections for cleanliness and corrosion. Clean up as needed. I and a few others like to use dielectric grease (a thick silicone based grease) to help keep moisture and oxygen out of connectors. There are aftermarket coils available. I've acquired 4 coil-on-plug coils from an R1 or some such that should fit and be fairly easy to wire up in tandem to replace the stock plugs. There is also at least 2 options for aftermarket TCI modules that can work with our FJ's.
In the Spring, on my first couple of shake down runs I like to go to a nearby parking lot and refamiliarize myself with my little beast to clean out any cobwebs and so we both get home safely.  good2
George D
Logged
George D
'89 FJ1250 ~'90-black/blue
gumby302ho
Sr. Member
Offline Offline
Gender: Male
« Reply #3 on: April 29, 2022, 12:42:55 PM »
  Well Lady Luck has treated me well this early afternoon. I pulled the top and sides off the ITX and was happy to see spark on 3 an4 but spark looked very weak on 1 an 2. Pulled all connectors apart and cleaned them up( DeoxIT D-series ) and put back together with yes sir I use the fancy diaelectric grease and cant stand that stuff on my fingers anyway I pushed the magic button and it fired after one rotation! yes got off easy there, thank you FJ. And as far as rider needs to get in tune for the season I believe that 100% and I think most should focus on slow speed skills, going fast is to easy its the slow speed skill that needs the seasonal tuneup! Oh and that cleaner I mentioned that I use came from the Audiophiles realm and used for old Hi-Fi gear which I bought it for. Dont laugh as I am a collector of old vintage Realistic Recievers. Next will be the avon first time for me radial tire on the back of my vintage 16 incher.
Logged
Super Hero Member
Offline Offline
Gender: Male
« Reply #4 on: April 29, 2022, 05:36:29 PM »
Great to hear you got it sorted easily. Hope you enjoy her. Those Avon's are a great choice
I have a feeling its going to be a great summer for you  good2
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 :: SMF © 2006-2009, Simple Machines LLC
SMFAds for Free Forums
Valid XHTML 1.0! Valid CSS!
