Fender and Forks From a 90
Started by woodcreekpete, October 18, 2021, 02:01:49 PM
woodcreekpete
Parting out a 90 that I dragged home a couple of weeks ago.
  Front fender is in very good condition - tabs on the front half are excellent, rear has a couple of cracks. Might have been repainted - paint is very good. $90 for both
Forks are in good shape. Will need a complete rebuild. Minor pitting on 1 leg in the area between the trees. Sliding surface on both legs is smooth and clean -  $120.  With a pair of good blue dots with good pads -  $150. I have the original wheel with the axle, spacers and speedo drive (discs are done) and an R1 master which I'll donate for nothing.
  Thanks,  Pete
woodcreekpete
Lowering the ask on these -
Fender - $70 for both halves, plus another rear half with good tabs, red though
Forks - $125 -  blue dots are gone, there's another front wheel with a good BT -45 on it.
Other stuff I need to part with:
    Supertrapp - all stainless, couple of the header pipes are dented . I trimmed a bit off the can (about 3/8 - 1/2" to clean up a tad of rash. Overall, it looks quite decent. Repacked.   Mount fits 91 and newer and probably 84-87  $175
    F1's fit same years. Very nice condition. Fresh repack. Minor denting on the tapered part of the left side - probably wounded by the center stand. Cans are in great shape. $175
    90 Motor - about 50k miles. Sat for a couple of years. I swapped out the carbs for a clean set and it fired right up - no smoke. Compression of 130-135 for all cyls using a dead battery that would barely turn it over. I was told by the guy I bought it off that the clutch slips. Comes with starter and alternator.  $500 or $650 with the carbs.
   Another motor. Don't know much about this one. Came with a bunch of parts I bought. Somebody's partially dis-assembled it - cams are out, clutch is out. All the parts are here for it.
   Carbs - 88 and up. Dis-assembled and ultrasonic cleaned for a couple of hours. Run them as they are, or buy one of Randy's kits and make them like new. $150
  Gauge surrounds - 1 or 2 to fit 88-90, 1 for 91 and newer. Good shape, all the tabs are intact. $40 per.
  Relay arm 88-90. Good bearings. $30
  Clutch cover no dents. $20
  88-90 fairing. Looks fine from the outside. Has had more than a few repairs on the inside but is ready to bolt on. Quite pricey to ship though. $125
  Free stuff - any or all of the rubber bits for the cost of shipping.
Thanks, Pete
benwjj42
Any idea what shipping would be for the forks to NY?  Seems easier than making brackets for my 84 to put blue dots on.
woodcreekpete
A rough guess would be $35-40 for the legs only - I'd have to box it up and weigh it to get a definite cost.
Made a mistake in the lowering of the price - forks are $100 US - not $125.
RPM - Robert
Drain the oil and take the springs out. Ups, fed ex, dhl, etc have gone to dimensional shipping. Even though they may weigh 10 lbs only. They will charge you for 50 lbs instead because the box is "oversized".
benwjj42
Are the forks still available?
lmahs92
Quote from: woodcreekpete on October 18, 2021, 02:01:49 PM
  Thanks,  Pete
id like to buy the front fenders!!!!!
lmahs92
 :dash2:    message me please i want the fenders!!!!!!!!
