Camshaft Chain Tensioner mounting direction
Started by xnr, September 11, 2021, 04:43:12 PM
xnr
Hi guys,
I checked my camshaft chain tensioner because I heared a ticking sound coming out of the engine block.
Since everything is fine with it i am about to reinstall it. (Good That everything's fine with the tensioner but I don't got the cause of the ticking sound. But thats for tomorrow.)
The clymer repair manual clearly states that the one way camshaft (See attached picture, in red) should face UP.
It just does not fit well with the one way camshaft facing up. Also on this drawing
it seems to be installed the other way around.
Does anyone know what's the right way to install it? Thanks guys!
I drive a 1200 1xj 1986
oldktmdude
   The manual is wrong, the ratchet (circled area) is mounted facing down. There are quite a few mistakes in the aftermarket manuals.
  Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
xnr
Quote from: oldktmdude on September 11, 2021, 05:06:56 PM
   The manual is wrong, the ratchet is mounted facing down. There are quite a few mistakes in the aftermarket manuals.
   Regards, Pete.
Thanks for that fast answer Pete! I mounted it this way.
Greets, Felix.
FYI, we have saved a good discussion on the proper installation of the cam chain tensioner over in the General Maintenance Files.
See Randy's post Cam Chain 101
http://www.fjowners.com/index.php?topic=3469.msg38278#msg38278
Spot on Pete!
xnr
Quote from: Pat Conlon on September 11, 2021, 05:48:12 PM
This would have saved me some time.
I tried the search engine but for some reason that one did not show up...
Another member or two has suggested to use Google. When searching make sure fjowners.com is in the search. I have had better results with Google than the internal search function.
Quote from: FJmonkey on September 11, 2021, 06:39:41 PMAnother member or two has suggested to use Google. When searching make sure fjowners.com is in the search. I have had better results with Google than the internal search function.
Good idea.
To that end, when you crank up Google, you can put in your search terms, followed by:
SITE:fjowners.com
This tells Google to limit the Search to just this one web site.  The SITE: command works for any web site, of course.  HTH.
I know for a fact that the Haynes manual tells you the ratcheting pawl faces down.
1990 FJ1300 (1297cc) Casper
Quote from: aviationfred on September 11, 2021, 07:39:18 PM
In the illustration that Felix posted, looking at the profile of the adjuster body, it sure looks to me like it's facing down.
xnr
good idea, I will try that next time
I mounted it the one way camshaft facing down and it surely is the right way, thank you guys!
Felix
f4fwildcat
The ticking you heard could be the end play in the camshafts, I've seen it mentioned on the forum here that you can hear a ticking from the top side of the left cylinder that might be what you're hearing seeing as no one has mentioned it. Mine does it when hot and sounds almost like a tappet with too much clearance.
xnr
Quote from: f4fwildcat on September 13, 2021, 04:06:00 PM
Thanks cat! I think thats what I am wondering about.
I made a video and one can hear clearly that it comes from the left side of the cylinder block:
https://youtu.be/EBBQ1dOZw_Y
Is it likely that this noise is caused by the camshaft end play?
Is there anything to worry about?
