Belly
Started by Diddly, April 10, 2021, 03:20:50 PM
Diddly
Hi all, have a 1992 fj1200, looking for bellypan and luggage rack if anyone has them.
Thank you
FJ1200W
Quote from: Diddly on April 10, 2021, 03:20:50 PM
Thank you
Still looking for a luggage rack?
Columbia, Missouri
USA
Good luck finding a used one in decent shape.
I ended up buying a new one
https://www.ebay.com/itm/174419986634
It was expensive by the time I had it painted, decals applied and insulation applied.
Never attempt to use the lower cowl without heat shielding, you will be sorry.
wco56
Quote from: Pat Conlon on June 13, 2021, 09:56:11 AM
Pat, I will also be in search of a belly pan and decal set for my 86 FJ. Any reason you chose the one from the UK as opposed to the one from Germany? Also, any recommendation on where to get the decal sets? And, if that's not enough, any chance you have modern paint equivalents to the Stormy Red and Silky White? Thanks.
Check with Robert or Randy at RPM. Last I saw they 2 fiberglass ones up on a shelf. Looks like the Ebay one. It will need the holes drilled, paint, decals, and heat shield as well.
Quote from: wco56 on October 06, 2021, 04:36:03 PM
I think the ones that come from the FJ Owners Club in the UK have extra reinforcement around the lower mounting points to help prevent the cracking that happens to a lot of the original ones.
Here is a complete 1986 decal set
https://rddecals.afegraphics.com/index.php?adminshopping=&cat_id=19215&catname=%271986%20FJ1200%20Red-White%27
Paint for the Silky White
https://www.colorrite.com/product/yamaha-00ge-silky-white-sw-1752.cfm
Paint for the Stormy Red
https://www.colorrite.com/product/yamaha-00aj-stormy-red-smr-1744.cfm
1990 FJ1300 (1297cc) Casper
wco56
Thanks guys for the info on paint and decals. I think this will be my winter project this year as the FJ has some body and paint defects that I would like to address.
