FJ1200 3XW stuff for sale - shed clear out
Started by FJools, September 11, 2020, 06:30:57 PM
FJools
Located in Sydney, which is why I put them on here.
In the process of clearing the shed and packing for a move, so the following I've decided to advertise on here before they go to ebay/gumtree.
1 Wibers shock absorber type 640 Road, blue spring -  very little use. set up for 100kg rider. $A 800 (cost me $A1200 delivered)
FJ1200 3XW WIlbers by Julian Hardy, on Flickr
2 Delkevic Oval Carbon Can complete system very good condition. $A500
FJ1200 Delkevic by Julian Hardy, on Flickr
3 Tail unit in reasonable condition. Nothing broken, few marks from rack fitment, needs a repaint ideally $A60
FJ1200 3XW Tail Unit by Julian Hardy, on Flickr
4 RH Side panel bottom tab broken otherwise complete paint is in reasonable condition $A50
FJ1200 3XW RH Panel by Julian Hardy, on Flickr
5 Rear Light good condition $A80
FJ1200 3XW Real Light by Julian Hardy, on Flickr
6 Grab rail undamaged $A35
FJ1200 3XW Grab Rail by Julian Hardy, on Flickr
7 LH engine sprocket cover good condition apart from paint lifting around slave cylinder mount. $A75
FJ1200 3XW Case by Julian Hardy, on Flickr
8 Belly Pan - cracked and repaired in places. needs some TLC. ideal for someone good at plastic welding  :smile: $A25
FJ1200 3XW Belly Pan by Julian Hardy, on Flickr
There will be other parts coming on here as I find them. I know I have a HID light fitting kit that's brand new in the box never fitted.
These are from my 1992 3XW, which i have basically put back to standard, other than the 17" rear wheel mod, ready to sell.
Troyskie
G'day Jools,
I'll grab the belly pan.
I would grab the shock, but i don't think it will fit my bikes.
Troyskie
FJools
Quote from: FJools on September 11, 2020, 06:30:57 PM
Edited to remove sold items - October 6
3 Tail unit in reasonable condition. Nothing broken, few marks from rack fitment, needs a repaint ideally SOLD
6 Grab rail undamaged SOLD
7 LH engine sprocket cover good condition apart from paint lifting around slave cylinder mount. SOLD
8 Belly Pan - cracked and repaired in places. needs some TLC. ideal for someone good at plastic welding  :smile: SOLD
FJools
The bike is sold, sadly, so I really need to shift these items before I move to SA
Reduced the Wilbers shock to $500
Delkevic Exhaust to $350
Also have HID headlight kit unused never installed $150
Pair of as new mirrors # 4FM-26290-10 and 4FM-26280-10     $80
Instrument cluster with GPS Speedo and antenna.      $160
50H-14940-00 genuine Carb diaphragm and slide NOS.      $65
Set 4 new genuine carb clamps # 90460-52264. $60
Set 4 Tour Max float needle kits. New unopened $80
3XW. Rear wheel $150
3XW Swing Arm $100
PM me for photos
Quote from: FJools on February 17, 2021, 02:43:13 AM
That's a great shame Jools, after all that engine work, I hope the new owner appreciates it. Your bike was probably the smoothest FJ I've ever thrown a leg over.
Are you moving to SA over the border or SA over the ocean?
Best of luck.
PM me for photos
What brand is the GPS Speedo?
1990 FJ1300 (1297cc) Casper
Quote from: aviationfred on February 17, 2021, 06:37:13 PM
PM me for photos
Fred, that's only $125 US.
FJools
Quote from: ribbert on February 17, 2021, 05:36:52 AM
Best of luck.
Thanks Noel,
I do miss the old beast but to be honest I didn't use it much after the broken wrist and frozen shoulder. It became uncomfortable riding for more than 20 minutes.
That's gradually improving fortunately.
I'm moving to Adelaide mate, interim stop before the UK thanks to covid !
FJools
PM me for photos
Hi Fred, it was a Speedhut unit from the USA -  I think I saw then mentioned on here somewhere.
FJools
Quote from: ribbert on February 17, 2021, 07:31:18 PM
PM me for photos
And you get a tacho and fuel gauge thrown in ! the downside is its in Kmh, but you can probably get a MPH dial for it.
Quote from: FJools on February 17, 2021, 07:40:58 PM
PM me for photos
PM sent
FJools
Update 18 Feb 3:00pm
Pair of as new mirrors # 4FM-26290-10 and 4FM-26280-10     $80 SOLD
Instrument cluster with GPS Speedo and antenna.      $160 SOLD
Set 4 Tour Max float needle kits. New unopened $80 SOLD
3XW Swing Arm $100
PM me for photos
Jeff0308
Hi Julian.
I sent you a PM about the dash.
Regards. Jeff
Jeff0308
how good is the bellypan , the side covers and is the exhaust loud or quiet?
jeff
Quote from: Jeff0308 on February 18, 2021, 12:05:43 AM
jeff
With the Db killers installed, Delkevic mufflers are slightly louder than OEM mufflers.
