How to remove gas tank filler cap
Started by aigram, December 07, 2019, 02:41:52 PM
aigram
Unfortunately there is a foreign object in my gas tank, and it's stuck. I need to remove the entire gas cap assembly in order to have better access with a parts grabber tool. Are the allen bolts around the outer ring of the gas cap all that need to come out in order to remove the gas cap assembly? Are there any seals or gaskets that could likely be destroyed by removing the gas cap?
Alex
1989 FJ1200 3CV
Going by memory, there are only 3 Allen bolts that actually secure the cap assembly to the tank, with one of the allens under the cap hinge....you have to unlock and open the cap to get to it.
You can remove all the extra allens on the trim ring.
No gaskets are involved.
Quote from: aigram on December 07, 2019, 02:41:52 PM
Unfortunately there is a foreign object in my gas tank, and it's stuck. I need to remove the entire gas cap assembly in order to have better access with a parts grabber tool....
If it's big enough to require removing the cap assembly to remove it and it's "stuck", how did it get in there and how did it get stuck, are you sure you're not looking at the sender unit for the fuel gauge?
aigram
It is most certainly not the fuel level float :)
How did it get in? It fell in. And then found a nice nook to jam itself in.
Thanks, Pat. I found the 3 Allen's you mentioned. Are you saying that the Allen's around the ring of the fill cap are just for that piece of trim?
Alex
1989 FJ1200 3CV
RPM - Robert
To remove, there are thee on the outer ring and one under the cap for all flush mount FJ caps.
Just take all of them out, no biggie.....you'll see where the long ones are....
Quote from: aigram on December 09, 2019, 04:58:49 PM
Whoa....ease up there....we're only trying to help.
I don't know you, so all I have to go on is your question at face value and that set the bar for the response. You asked how to remove the fuel cap, if you need to ask that question (and there's nothing wrong with that) it is reasonable that the appearance of the fuel sender unit may not be familiar to you (and the fact that large unidentified foreign objects wedged in fuel tanks without explanation is hardly common!).
....just out of interest, what is the foreign object?
aigram
Thanks Robert, cheers.
The culprit is a skinny flathead driver. While draining the tank I inadvertently knocked it in. Trying to get it out I believe I may have pinned it behind the fuel level assembly.
It wasn't the best of Sunday afternoons in the garage.
Alex
1989 FJ1200 3CV
Paul.1478
2006 GL1800
2022 Ducati V2
1976 RD400
1993 FJ 1200 ABS
T Legg
I couldn't help imagining an illegal alien hiding in the tank.
T Legg
aigram
Got it out, thanks all for the insight. The trim ring holding the filler cap assembly together really seems a lot less official now that I know only 3 bolts in the whole thing actually attach it to the gas tank body...
Alex
1989 FJ1200 3CV
Quote from: T Legg on December 10, 2019, 03:40:00 PM
NO ONE is ILLEGAL! How DARE YOU! /s
Quote from: ZOA NOM on January 07, 2020, 12:40:55 PM
Maybe Travis meant unauthorized for entry of enclosed spaces. Don't want to OSHA involved.
