intermittent tachometer issue
Started by the_kirkwood, December 03, 2019, 03:43:20 PM
the_kirkwood
Tachometer is bouncing erratically at idle.  When riding it normally drops to zero rpm with some random twitching from time to time.
Is this likely to be a bad tachometer, bad signal to tachometer or maybe a bad ground?
Is it common for these tachometers to go bad?
thanks in advance
1986 fj1200
The ground connection is almost always the issue.
the_kirkwood
1986 fj1200
Also to check is the grey signal wire coming off your right side #2/3 coil. Clean that connection.
