Braided brake lines.
Started by crash7863, June 29, 2019, 07:34:54 PM
crash7863
I've got existing braided lines with stock brakes in front. I'm about ready to swap over to a 14mm banjo master cylinder. I believe I need to replace the lines as the banjo bolt diameter would be different. Am I correct in thinking this?
The brake lines will work with the new 14mm master.  The banjo size will be the same.
14mm is the diameter of the piston within the master cylinder.
The banjo's the same same.
crash7863
That is the best news I've received all week. Thanks.
