Starter Motor Noise
Started by Sparky84, June 22, 2019, 10:15:07 PM
Troyskie
Red and Hooligan, I'm pulling my bike apart for all sorts of things not related to this.
I think I'll follow what you've both suggested. No need, as it seems to work fine.
However, after 35 years I think a bit of service might be due.
Sparky84
Quote from: Troyskie on August 31, 2019, 03:43:09 AM
Noice!
Being black should match the original.
Was it plug and play as it seems from your post?
It seems it was but I didn't measure the length back to the o ring and gear, but I did have a bit of trouble installing it, which was good as it meant it was the gears meshing.
But it works so all good
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
Troyskie
Quote from: Sparky84 on August 30, 2019, 02:54:39 PM
So how can I tell what model it is ? There are no markings on it apart from some on the black cover which don't correspond to anything.
Sorry, I missed this earlier.
The two brush starter motors have a phillips/JIS screw in the body which hold the two magnets.
The four brush starters have the magnets epoxied in and no visible screws.
Sparky84
Quote from: racerrad8 on September 01, 2019, 07:05:52 PM
Good to know, one taken out had the screws and now I know what they were for, other had no screws.
But I have noticed a slight howl still there when starting, like a dry bearing but not all the time that starter is engaged, more as it's just started and finger is coming off button.
1979 Kawasaki Z1300
