need comments about rear preload on a progressive monoshock
Started by mtc, April 28, 2019, 05:41:23 PM
mtc
I got a used one off scambay, in very good looking condition
it has threads and collars,
not like the one with steps
i am lightweight around 140 lb with gear on a heavy day
the rate stamped on the spring says #1181 850/1200
maybe it means progressive at 850lbs then 1200lbs idk
anyone can comment on how i should adjust the preload as a baseline before i install it?
it's a bitch to do it now, i can't imagine doing it on the bike
should i back it off all the way and give it 1-2 mm preload, i reckon, i don't need much at all and perhaps the spring is too heavy to begin with and i am not gona swap it out
thank you again fjowner's
Previous Bikes
1979 Yamaha XS1100 best one
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
1978 RD400 Spec II Motor
Live Life Wrong and Perspire
mtc
Quote from: mtc on April 28, 2019, 05:41:23 PM
gona try to install it, and share more pics hope i don't screw it up
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
