I seached but cannot find how to install the 87 fj12 airbox fj11 won't line up
Started by mtc, March 28, 2019, 05:03:22 PM
mtc
the #2 boot seems too far away, i kepted the frame bolts loose andi loosen the carbs so it can tilt up a little but it won't line up.... freakin help!,  someone here has to know the trick to this, i did use and long hose for the crankcase vent so no problems there
Previous Bikes
1979 Yamaha XS1100 best one
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
1978 RD400 Spec II Motor
Live Life Wrong and Perspire
Maybe a heat gun to get all the rubber bits more pliable. Been a while since I had an air box. Check to see if the rubber boots are eccentric, I think they might be. If so then rotate them till they align better.
These boots are eccentric, so, as you rotate them their position changes, up, down, left and right, individually.
These lugs locate them in the correct position to line up with the carbies. If they are not lined up it makes a difficult job even harder, or, even impossible.
The singular lug on the boot sits between the two lugs on the box.
mtc
Quote from: ribbert on March 28, 2019, 06:11:01 PM
i lines them up and they don't line up with the carb  :dash1:
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
mtc
Quote from: FJmonkey on March 28, 2019, 05:50:45 PM
i might try that i have a hair dryer  :bad:, i wonder if it's only yamaha that makes airboxes so tight, or is it like a heater core replacement, all of them are nightmares?
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
mtc
Quote from: Pat Conlon on March 28, 2019, 06:50:54 PM
Quote from: mtc on March 28, 2019, 05:03:22 PM
.....someone here has to know the trick to this....
We do
if i give up, that will be my choice, the singles i had in there from the PO fit just as poorly as the airbox and they  are ugly and they suck bigtime
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
mtc
can i just pull the carbs off the motor and put that part in last?
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
mtc
the sell of the box, had 2 of the tubes in the wrong hole, there are outers and inners, and that is just the start of the hell
done, all the low end is back, and pulls harder
nightmare royal pita, mm by mm
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
mtc
yeah, it's in and quiet, torqey  and less vibration
i know it nothing for you guys with major projects but it's my limits
Previous Bikes
1987 FZR600
1987 Fazer
1985 Vision
1982 Seca 750
