F up?
Started by Tor-King, January 21, 2019, 08:35:39 PM
Tor-King
So, I rebuilt my engine for my '86.  Things went really well thanks to the help I received from Randy!  Installed the engine, hooked everything up, double and triple checked fasteners, electrical.  I then put in my oil to the full mark... a little over 3.1 litres (3.4 quarts)...  Fired right up with no coaxing.  Took a bit to burn off oil and to get it to run smoothly (getting the fuel to flow as the carbs were also rebuilt --3-4 minutes).  I was so preoccupied with this that I did not realize that the oil light was on.  I shut it down only to realize I was a litre low!! I put a litre in and fired it up again.  :Facepalm: Light went off.  Did I F anything up?  There are no odd noises, rattles... The engine runs incredibly smooth!
1993 Yamaha FJ1200
1988 Yamaha FJ1200
1986 Yamaha FJ1200
1984 Honda Nighthawk S 750
1972 Yamaha XS-2
1972 Honda CT70
1974 Honda CT70
1992 Yamaha DT50 MX
2012 Honda CBR250R
2008 Honda CBR125R
Nope, no worries. I think you're fine. I've done the same thing with my Porsche motors (also air-cooled).
A quart low is still plenty of oil to lube the engine at idle. I am not sure where the low oil level and higher revs become dangerous for the engine. But the oil is picked up from the bottom of oil pan so the oil pump did its job.
Tor-King
Quote from: FJmonkey on January 21, 2019, 09:05:42 PM
Hey Mark.  The problem is I did rev it a little to keep it running until it finally cleared itself...
1993 Yamaha FJ1200
1988 Yamaha FJ1200
1986 Yamaha FJ1200
1972 Yamaha XS-2
1972 Honda CT70
1974 Honda CT70
1992 Yamaha DT50 MX
2012 Honda CBR250R
2008 Honda CBR125R
You could rev it to 5k for an hour with that much oil. Ride that SOB and enjoy your hard work.
Tor-King
Yea!  That is what I was hoping to hear.  Thanks!
1993 Yamaha FJ1200
1988 Yamaha FJ1200
1986 Yamaha FJ1200
1972 Yamaha XS-2
1972 Honda CT70
1974 Honda CT70
1992 Yamaha DT50 MX
2012 Honda CBR250R
2008 Honda CBR125R
Read this.
I don't mean to be dismissive of your concerns. I know I fret for the first several hours of run time on my race motors. These FJ motors are very robust, and just keep on running. I would keep your rpm's reasonable for a break-in period, and listen for odd sounds, but once you're comfortable, I would run it as hard as you like.
Tuned forks
Wow, that was a great read Rick.
1990 FJ1200-the reacher
1990 FZR 1000-crotch rocket
