shims
Started by REXNFX, December 13, 2018, 09:53:19 PM
REXNFX
having just picked up a 1985 FJ1100and not knowing the history behimd the bike,i would like to perform a valve check. i do not have any shims. do you guys work off of a kit that you own or do you buy shims as you need them? if i wwere to order a kit, where is the best place to order from?
Welcome aboard! You came to the right place.
Try our host.
Or...... You can use the Rental Shim kit.
Click on the blue link..... http://www.fjowners.com/index.php?topic=8968.0
balky1
Even if you do need to buy them, it is rarely needed more than 2-3 pieces. Most can be swapped between valves.
FJ 1100, 1985, sold
FJR 1300, 2009
T Legg
I'm adjusting the valves on my new fj1100 loaner bike and my#3 cylinder #2 intake valve was too loose with a 265 mm shim and too tight with a 270 mm shim.most normal people would put the 265 mm shim in and not worry about it,but it bothers me to be out of spec.I went to my local Yamaha dealer and he brought out a box of 25mm shims for Triumphs and they had most of the half sizes.I now have,2.35,2.40,242.5,245,247.5,250,255,260,262.5,265,267.5,270,272,272.5,275.I don't know if all triumph dealers carry these sizes but it's worth asking.they charged me $ 4.50 each.
T Legg
Motofun
Interesting....I know my old CBX used shims that were identical to FJ shims.  I wonder what other makes used similar shims?  Also, I mic all my shims and find there are significant differences between what is stamped on them and what they actually measure out as.
'75 Honda CB400F
'85 Yamaha RZ350
'85 Yamaha FJ1100
'89 Yamaha FJ1200
'09 Yamaha 125 Zuma
'13 Suzuki GSXR 750 (track)
'14 Yamaha FZ-09
'23 Yamaha Tenere 7
T Legg
My CB900F also uses 25mm shims.I bet there are more 80's bikes that use them
T Legg
RPM - Robert
We stock all the regular sizes from 200-320 and all the half sizes from 252-292 Genuine Yamaha Valve Shim
balky1
Someone said to me that VW Golf Mk1 uses the same shims.
FJ 1100, 1985, sold
FJR 1300, 2009
chiz
Re shims and clearance, my old push rod triple takes a .006 and .008 but it is the norm to increase this one or two thou, is this so with the 1100's?
Lez
Old Rider
Quote from: balky1 on December 14, 2018, 01:44:31 AM
Sometimes you need more Yesterday i bench shimmed the head and even i had 8 shims extra i need to buy 9 new shims .Going to make an order from RPM.
Old Rider
Quote from: RPM - Robert on December 28, 2018, 10:07:55 AM
I did not find 248 when ordering ist it sold out then ?
Uppdate i se now why i did not find 248  :bye2:
RPM - Robert
248 does not exist in Yamaha size. 200-250 and 295-320 are in .05mm The 252-292 come in the half sizes as well as the .05mm increments.
T Legg
If you need the 248 call your local triumph dealer
T Legg
