sprocket choices...
Started by twangin4u, June 01, 2018, 11:36:23 PM
twangin4u
I have 17/42t on an 18" wheel. Its time for a new chain and im contemplating changing up sprockets for the heck of it.  Im wondering if I do change and im not happy would adding a tooth or two be possible with the existing chain? Is there enough adjustment for it?
fj-f3a
The centre to centre distance of each link is 5/8" (16mm), therefore 5/16" of adjustment would be required for each additional tooth added or removed.
An 18/40 front/rear should be OK but an 18/38 may require a shorter chain.
I run an 18/38.
What is the circumference of the 18" tyre. An 18/40 or 18/42 may be a good choice.
Wings Level
1990 FJ1200, Wet Pale Brown
J17xMT5.5 rear wheel from a 2001 Kawasaki Zx9r
Stainless exhausts
Electronic cruise control
Custom seat
Yamaha R6 Blue Spot Callipers
FJR1300 Master Cylinder
Stainless brake lines
