Earl's Cooloers
Started by timleslie1957, May 08, 2018, 01:15:19 PM
timleslie1957
Hi gang:
Anyone ever use any of Earl's products?  I was thinking of this https://www.jegs.com/i/Earl%27s/361/21000/10002/-1?utm_source=criteo&utm_medium=cpc&utm_campaign=retargeting or something similar.
Tim Leslie
"A bike and curvy roads ... priceless."
Yes we have, Earl's and Setrab coolers were a popular choice, years ago. Your link shows a 10AN cooler. A 10AN line is too big for our FJ's.
What I have found is that by the time you add the cost of the cooler along with the cost of AN lines, AN fittings, oil pan fittings, mounting brackets (rubber isolated) and an inline oil thermostat, I was money ahead using RPM's oil cooler kit.
http://rpmracingca.com/proddetail.asp?prod=M%2FC%3AFJCoolerKit&cat=27
FYI Here is a write up from the Mod. Files on installing a Setrab cooler:  http://www.fjowners.com/index.php?topic=676.0
What is missing from Carey's instructions is the oil thermostat. Proper oil temp. is important.
Cheers   Pat
JMR
 I run Earl's coolers on 2 bikes. The quality was better when Earl's was independently owned. They were bought some years back along with, Holley, Mr Gasket etc by a conglomerate and they aren't made as well as they used to be. The Setrab units are high quality.
chiz
Jeez looks almost identical to the one on my Rocket3
balky1
I always wandered if the OEM coolers had some thermostat?
FJ 1100, 1985, sold
FJR 1300, 2009
chiz
No they did'nt Folks have fitted them though for the initial warm up.
