April 2018: The List
Started by FJ1200W, April 10, 2018, 06:24:32 PM
FJ1200W
Greetings all - Merry Christmas and Happy New Year to each and every one of you!
My wife (Ninja 250) and I were able to ride a couple days ago, it was nearly 70 here in the midwest - loved it!
I noticed my FJ is vibrating a lot more than normal, and I think it's why I've had some plastic crack and possibly killed my battery.
So I guess the time is here to do something about the mounts. And maybe get going on the other tasks I was to get done.
I've left my last job and have a window of maybe 60 days. Hopefully it works out.
Wishing you the best,
Columbia, Missouri
USA
FJ1200W
Please see attached, I may have found the starter drive for the motor I want to try out -
Does this look complete?
Columbia, Missouri
USA
Steve, not sure about the internal bits but the starter in the image is the older 2 brush style. Consider getting the improved 4 brush for better hot starts.
without full disassembly, there is no way of know if it is complete.
FJ1200W
Busted the FJ out two days in a row, loving this weather!
Yesterday it just seemed a little flat - then I noticed the chock partially on and oh yeah!
Awesome machines
Columbia, Missouri
USA
FJ1200W
Well, I'll wait to ride, I guess.....
Columbia, Missouri
USA
Quote from: FJ1200W on April 26, 2020, 05:52:27 PM
That's an obvious sign of jealousy due to all the attention to the other FJ heart you are caressing. :pardon:
FJ1200W
Quote from: racerrad8 on April 26, 2020, 07:10:23 PM
You could be correct, absolutely correct.
I was going through some boxes and found what I think was the plug for the alternator - Vented?
And also found a stock ignition.
Columbia, Missouri
USA
FJ1200W
I dropped my block off to me milled. It seems the sleeve(s) slipped.
The machine shop is supposed to check them and make it flush.
$100 seems fair
Now to search for cylinder wall clearance recommendations - I'm all ears.
Columbia, Missouri
USA
FJ1200W
Block's back and it sure looks better.
I'll do a final hone and call it good.
Columbia, Missouri
USA
Quote from: FJ1200W on June 16, 2020, 09:24:51 AM
Excellent, just about there. Do you still plan on re-using the old rings?
FJ1200W
Quote from: ribbert on June 17, 2020, 08:45:03 AM
Yes, they appear as new.
If I have any issues upon final inspection, they'll be replaced, but so far, so good.
:good2:
Columbia, Missouri
USA
