ABS service light stays on
Started by aviationfred, March 24, 2018, 05:57:47 AM
I am hoping someone can tell me the quick remedy to get the ABS service light to not be on. I have removed 90% of my ABS system. The only part that remains are two brake lines for the rear brake and the rear ABS sensor in the rear wheel.
I have not had a chance to look at a wiring diagram yet. I have removed the ABS fuse, I figured that would keep the light from coming on.... Nope.
1990 FJ1300 (1297cc) Casper
oldktmdude
   Remove the light bulb. Guaranteed to never light up again!   :good2:
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Quote from: oldktmdude on March 24, 2018, 06:01:55 AM
Can't argue with that.
TexasDave
Quote from: aviationfred on March 24, 2018, 07:02:29 AM
.22 cal would be about the right size and fastest.   :biggrin:
FJ1100mjk
Quote from: aviationfred on March 24, 2018, 05:57:47 AM
Remove bulb!!!???!!! Meh.
You want quick?...
You're welcome.
:Facepalm:
Iron Balls #00002175
www.ironballs.com
When I removed all the ABS electronics in the rear tail, the light never came on.
However, I never checked to see if the bulb was blown.
I seem to recall removing two ABS fuses from the box. My bike has the complete system on it with the fuses removed. ABS does not function and there are no lights illuminated on the dash.
Quote from: racerrad8 on March 24, 2018, 04:27:05 PM
I took out the "ECU" and "warning" fuses.
Quote from: FJ1100mjk on March 24, 2018, 10:28:27 AM
You want quick?...
You're welcome.
:Facepalm:
That is awesome.... definitely works without even needing to break out the tools.
The 3Amp warning fuse did the job, thanks Randy.
