Vacuum Fuel Tap leaks
Started by Sparky84, February 28, 2018, 11:52:50 PM
Sparky84
Just turned fuel tap to PRI position to fill up carbs and noticed fuel leaked out around Knob and enough to wet the side of the carb heat protector below, it wasn't dripping but the initial turn did it, maybe o-ring behind knob if there is one. Its back in ON position and no weeping all dry.
Is there a kit or do I replace the entire tap assembly and if so what other than tap assembly do I need?
All this the night before a three day trip :dash1:
I'm still going I hope
Cheers Alan
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
balky1
There is an O-ring if my memory serves me. And a rubber pad with holes, but that is not your problem. Change that O-ring and you are good to go. Bad thing is I think you need to remove the tap from the tank so you'll probably need the O-ring between tap and tank and maybe the gaskets on the screws that hold the tap on the tank (although I've reused those with success).
Randy and NRP carbs have kits (I had problem with their kit because the smallest O-ring - the one that goes to the plunger - wasn't sealing), but any fuel rated rubber O-rings will do it.
FJ 1100, 1985, sold
FJR 1300, 2009
balky1
Randy's kit doesn't have the necessary O-ring as stated on the web. Sure he can get one. This middle one is needed: http://www.nrp-carbs.co.uk/shop/index.php?route=product/product&keyword=FJ1100&product_id=4140
On the other side, Randy's kit has items that this one doesn't.
FJ 1100, 1985, sold
FJR 1300, 2009
oldktmdude
   Alan, if it does not leak in the run position don't fuck with it until you return from the ride. You don't need the "prime" position unless you run out of fuel.
So don't run out of fuel!
   Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Sparky84
Quote from: oldktmdude on March 01, 2018, 03:15:41 AM
   Regards, Pete.
I won't be touching it until after Mudgee, if it ain't broke....
I'll try not to run out but I don't believe the PRI is classed as reserve, if you have to stop and take side covers to switch to reserve I don't think it is...
Cheers Pete
1979 Kawasaki Z1300
balky1
Quote from: Sparky84 on March 01, 2018, 06:00:33 AM
   Regards, Pete.
I won't be tou
Cheers Pete
Not a reserve, but you would probably need to prime the carbs if they are empty. Or crank it long.
FJ 1100, 1985, sold
FJR 1300, 2009
I used to have that same problem.  Petcock would drip when placed in the PRIME position.
I just never used PRIME and rode for several years before eventually replacing it.
I*f it's not leaking in the run position, you should be fine.
oldktmdude
Quote from: balky1 on March 01, 2018, 06:17:55 AM
That was the aim of my statement.
   See you in a few days Alan.  :drinks:
   Regards, Pete.
2009 TDM 900
2004 GasGas Ec300
balky1
Quote from: oldktmdude on March 01, 2018, 03:10:51 PM
   Regards, Pete.
Yeah, I got it. But he didn't I'd say.  :bomb: :biggrin:
FJ 1100, 1985, sold
FJR 1300, 2009
