Ethanol laced fuel: The corn lobby is at it again.
Started by Pat Conlon, January 08, 2018, 12:20:25 PM
TexasDave
I have previously posted on this topic several times. The powerful corn lobby lining the pockets of professional politicians are still trying to up the ethanol levels. Using corn to produce more ethanol drives up the cost of beef and chicken as the price of corn continues to rise. Brazil uses sugar cane to produce their ethanol which is considerably cheaper and requires much less water and fertilizer. Several years ago the EPA did a secret study in the DFW area. Raising the level to 30% without telling the public. Older cars started having serious problems. Ed Wallace noticed and submitted some to a lab where it was independently tested at 30% and the EPA was exposed. Here is another article by Ed Wallace.
https://www.wired.com/2009/05/another-argument-against-ethanol/
Dave
airheadPete
Gawd, I hate that stuff.
I go to the next town over to buy ethanol-free. It's not cheap, at about $3.85 a gallon, but but my things run better, and my gaskets & o-rings won't turn into jelly. Yes, that has happened to me.
(Everything I have is at least twenty-five years old or older. New stuff is designed to be compatible.)
'92 FJ1200.    '84 R100CS
'78 GS750E.   '81 R100RS
'76 R90/6       '89 R100GS
'65 R60/2
balky1
I don't know why you all complain about the fuel prices in USA. In Croatia one gallon is 6.05 USD with much much lower living standard (at least no ethanol in our fuel - yet).
FJ 1100, 1985, sold
FJR 1300, 2009
airheadPete
Have you seen the size of our cars & SUVs?  :scratch_one-s_head:
You could use them as school buses.
'65 R60/2
balky1
Quote from: airheadPete on January 09, 2018, 11:11:12 AM
Only on TV.  :smile:
FJ 1100, 1985, sold
FJR 1300, 2009
big r
Gas up here in BC is at 1.25 a liter. That works out to 5.00 bucks a gallon. Most pumps are only E10 with some stations having a choice of up to E85
I don't think we have to worry much. The E15 mandate failed miserably and adding even more ethanol won't be any easier to sell the American public. California on the other hand may see increased ethanol levels due to the environmental policies of Moonbeam Brown and the idiots running the State.
I drive one of those SUV school buses. It can seat 9 people.
Quote from: aviationfred on January 09, 2018, 12:01:26 PM
...California on the other hand may see increased ethanol levels due to the environmental policies of Moonbeam Brown and the idiots running the State.
Yea, Fred, you were reading my mind... I don't mind them offering ethanol laced fuel to consumers. I do mind them taking away my ability to choose.
Most of the ethanol free gas offered here in Calif is located at FBO's (air fields): https://www.pure-gas.org/index.jsp?stateprov=CA
....and unfortunately no pure gas offerings in my area. Thank God for VP fuel (used for storage). Expensive @$12 a gallon but sure worth it....
If I have to run E20, I wonder what it will do to my tune?
JMR
Quote from: balky1 on January 09, 2018, 12:35:26 AM
That is cheap. In Massachusetts there are no non ethanol pumps and I use VP non ethanol small engine fuel. I buy it in 5 gallon drums and when all is said and done it is still about 13.00 a gallon. Fortunately I don't ride the FJ a lot and it is fantastic fuel.
Troyskie
As Oz seems to blindly follow what ever political madness is going on in the US I see an ethanol future here as well, although the sugar lobby here is probably stronger.
E10 has been around a while & caused probably the same issues here. Perhaps we can be prepared.
A friend of mine is in that business (ethanol) & this afternoon I asked 'Can the ethanol be simply and easily (in my shed) removed?'
The answer is yes, and it is surprisingly simple.
I've yet to do this, as normal petrol and avgas is available to me ( :yahoo:). So the below is info passed on, but from a genuine industry leading expert.
His answer is that water will remove the ethanol. Mix water and petrol, then allow the water/fuel to separate. Decanting them will give you 'pure' fuel in what ever octane (I checked with him that removing the ethanol will not change the octane) you started with.
I've occasionally had to deal with water in petrol. It separates very quickly with petrol floating on water. Water looks like little drops of mercury in the bottom of a jar of petrol.
He also suggested using Kolor Kut post decanting, to check there is no water or ethanol left. Kolor Kut is an American made paste that will change colour if fuel has any of a variety of contaminants, such as ethanol and water. It is available in Australia from www.fuelequipmentspecialists.com.au . I imagine it is readily available in America.
Let us not forget that playing with petrol and making little explosions is a lot of fun. I am, however, writing this from my hospital bed (not an explosive accident) and don't want any FJowners joining me for the duration.
Troyskie
That's excellent info Troy, although ethanol is far more widespread in NSW than it is here, but that could change. It's one of those things govt can impose on us that costs them nothing, is popular with the voters and all the while pretending they care about the environment. Win win for them.
PaulG
Thats a good idea.  Easily done with one of these 5gal collapsible water containers you can buy anywhere.  Just tip it on its side and let the water settle on the bottom then drain out.
Is there a recommended ratio of water/gas to mix to absorb the ethanol?  Or would you just go by the same % of ethanol - i.e. if 5gal of E10 gas then add 10% water by volume - which would be 0.5gal of water?
PSA - please don't dump the residual water down the drain or sewer.  Put it in a shallow tray and let it evaporate - or use it for weed killer  :shok:
1992 FJ1200 ABS
YouTube Channel Paul G
Thanks Paul....is that container material safe with gasoline? Some plastics melt in fuel.
Troyskie
I did a quick web search and one of the EPA mobs (US I think) gave a formula of 3.8 tea spoons of water per gallon for e10 before the petrol will reach water saturation, and excess water will sink out.
I believe this is the ratio at which the ethanol will be dissolved by water.
This doesn't seem much.
3785ml to the gallon.
5ml to the teaspoon.
3.8 x 5 = 19ml. 10% of 3785 is 378.5. Can 19ml of water remove 378.5ml of ethanol?
I think this needs some testing :wacko2:.
Here's the link to the EPA document. Interestingly it also mentions the expected engine damage to occur from using ethanol. https://www.epa.gov/sites/production/files/2015-09/documents/waterphs.pdf
Someone who is more familiar with chemistry should check my maths.
