Can I add oil to my 87 fj1200 forks as a band-aid?
Started by Ryankhitt, November 13, 2017, 05:50:23 PM
Ryankhitt
So. I have leaking fork seals, but it has taken two years to have any real issues. I'm pretty sure I felt them bottom out as I almost t-boned someone making a left hand turn. What my question is: can I fill my forks without taking anything apart as a quick fix until I can get to a shop? There are no shops where I'm at and the closest one is 100 miles away. How hard is it to change your fork seals? I only assume it is best to have a shop do it. Thank you, everyone is super helpful on here.
Changing the seals is not that difficult. Adding oil requires pulling the seal out. Might as well put new seals in with fresh oil. Do you have a service manual for the FJ? One of the most critical tools I forgot to mention in my other post. Much can be down loaded from our files section. I made a seal driver from common plastic plumbing parts.
Ryankhitt
I don't own the service manual. Isn't there the air bleeder valve I can fill from? Were talking about an 87' 1200
FJ1100mjk
Read the files that were mentioned above, and look at Youtube videos of similar fork seals being changed. After that, you'll have an understanding of what it takes to change the fork seals. If it seems beyond your skill set, and available tools, then you should have a shop or someone that's capable do the repairs.
Iron Balls #00002175
www.ironballs.com
Urban_Legend
Hi. If getting to a shop is the sticking point. Declare a men's shed day,either with some local riders like I did last weekend, or with FJ members. People will travel if you can provide a bed and food, which is cheaper than shop labor costs. Swap knowledge, have a chat and some beers and get it fixed at the same time. There would be a rider somewhere near you that could help.
Mark
Mark
My Baby (Sparkles)
84 FJ1100/1200 motor
84 FJ1100 - Project bike.
CutterBill
Quote from: FJmonkey on November 13, 2017, 06:10:27 PM
...Adding oil requires pulling the seal out....
Say what?  To just add oil?  Whatever happened to: unscrew the upper cap, add oil, reinstall upper cap?  Yes, of course if the fork seals are leaking then they should be replaced but the OP is just trying to get by until he can get the bike to a shop. And as for the seal replacement being "an easy job" I think this might be beyond Mr. Ryan's capabilities. I don't know, but just reading between the lines...
Sure, replacing the seals is easy if you've done it before. If you understand tools and machinery. If you've had someone walk you thru it before. But for a newbie first-timer? I'm not so sure.
Ryan, yes you can add oil to your forks until you can get your bike to a shop. If the engine was low, you would add oil wouldn't you?  Same thing. Ok, a few notes here: those upper caps are the upper spring perches. Meaning they are holding the front of the bike up. Do one at a time or the forks will collapse on you. No damage but one heck of a geyser of dirty oil shooting out of the top of the fork. Also, if you look around files and various internet sources, you find a reference to the oil level being about 6 inches below the top of the fork.  That is with the fork  fully COLLAPSED. So how much oil do you add if the forks are extended? I dunno... maybe add an ounce or two?  Or maybe use some sort of skyhook or a jack to slowly lower the bike until the forks are collapsed, then add the proper amount of oil. Also, be careful to not cross-thread the upper caps when you reinstall. They are aluminum and very fine threads. If you cross-thread, you will (probably) never get them on straight.
Yes, replace the fork seals yourself if you have lots of time (so you can ask questions here) and a CLEAN place to work. Otherwise, take it to the shop.
Bill
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
CutterBill
One other thing I would like to point out while we are sitting around the digital campfire...
Read the OP's original post. Then read the replies and you will see that NOT ONE person (except me) answered his question.  All he asked was, Can I add oil? And every reply then proceeded to tell him that he should change the seals, it's not that hard, round up some buddies, watch YouTube, have a man-shed day... All good advice, except that none of those replies answered his question.
This one tendency for people to jump ahead and steer someone in a different direction just drives me nuts.  I know it's easy for us armchair experts to believe the fellow on the other end is an idiot (Oh Jeez, what was the name of that kid that cut off the tip of finger oiling his chain?) but sometimes the guy on the other end is just asking a question.  Let's help him out and simply answer the question first.  THEN we can launch into a discussion on the merits of which oil is best... (ducking for cover.)  Anyway, my 2 cents...
Bill
And Ryan... PUT YOUR LOCATION IN IN YOUR AVATAR. Maybe someone lives nearby and will offer to help...
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
[edit] Bill beat me by 4 minutes.....
You can drain the oil out and add new oil without pulling the forks apart.
It's best if you can remove the forks from the triple clamps, good to turn them upside down for complete draining, good to hold them vertical for oil level measurement... but even still, you can drain/add oil leaving the fork legs installed:
Lift the front end (Jack stands under front frame cradle) remove wheel.
Loosen fork spring preload to the lowest setting.
Loosen top clamp pinch bolts.
Remove fork cap
Remove fork springs.
Open up drain screws on the lower sliders, drain out old oil, (it takes awhile, be patient) at the end of draining, put the fork cap back on and move the lower slider up and down to pump out any residual oil.(springs removed)
Take cap back off.
Collapse lower sliders on the stanchion tubes, all the way up. Zip tie fork lowers to hold them up.
Add new oil. Be careful on your measurement, realize that your forks are on an angle so measure accordingly.
Cut zip ties, extend back down the lower sliders, add springs and fork caps, wheel, etc...
That said....you really, really really should fix your seals.
Leaking fork seals can get fork oil on your brake rotors and cause you to have a OMG moment.
IMHO it's better to ride with your forks dry, than chance compromised front brakes.
If you don't want to ride your bike to the shop with dry forks, take your forks off and drive them to the shop.
Cheers, please be careful.  Pat
 :blush: I jumped to my first thought of needing oil, bad seals.... As you were....
FJ1100mjk
Quote from: CutterBill on November 13, 2017, 08:41:23 PM
Read the OP's original post. Then read the replies and you will see that NOT ONE person (except me) answered his question. All good advice, except that none of those replies answered his question.
Yes, other previous replies did answer his question. The OP would only need to practice a little self help. Further, the OP's next obvious question was answered as well, and it all took less than two separate posts and 550 words too!
:Facepalm:
www.ironballs.com
whyzee79
There is the old dirt bike trick you can try for a fix.  We usually use a "tear off" and cut it down to make the tool so any super-thin tough, flexible plastic will work.  Cut it down to a 1"x4" strip.  Slip it in between the seal and the fork tube and go around the circumference of the fork to clean any dirt out of the seal.  You might get lucky and the seal might do its job at this point.  It works some of the time and saves you from doing a seal job.  If not, add oil in the top of fork and get it fixed.
Ryankhitt
So... Thanks for all the info guys. I feel the need to explain my mechanical capabilities. Not to impress but just so we're on the same page. Because of YouTube/internet...So far I have been able to: install dynojet jet kit (carbs), diagnose and replace shift shaft, replace inner boss hub (after breaking it during shift shaft repair) install new turn signals, diagnose and install new ignition, remove air box and install pod filters and always change my own oil. I had the shop install a new back tire and entire gasket kit. With that being said I have never worked on a motorcycle AND this is the first death chariot I've owned... It mostly a time and tools reason I don't do my own repairs. All I want to do is add oil to my forks. There are some things I understand are better left to professionals... However I've done all of my repairs out of necessity because most shops won't touch an 87'...
I don't see the fork seal R/R instructions in the files section.  Used to be a detailed process for accomplishing the task along with the instructions for making the 3 special tools.
The hardest tool to buy/make is something to remove the fork caps and hold the damper rod in place while removing and re-installing the damper rod holder bolt (10mm allen bolt on the bottom of the fork slider).  This tool is easy to make if you can find an M18 hex head bolt.  This bolt has a 27mm head and fits the fork caps and the damper rod.  Next, get a 5/8ths inch deep well, 12-point socket in your choice of drive size (3/8 or 1/2).  Take a BFH and beat the socket onto the threads of the bolt.  Instant fork tool!  An M18 bolt is not too common.  Others have used an oversized SAE bolt (~1-1/6 or 1-1/8 inch head size) and ground it down to fit.
Use this tool to disassemble the forks in accordance with instructions in the manual.
Next, you need a fork seal driver.  Easiest solution is to purchase a generic fork seal driver (Motion Pro) or an FJ-specific 41mm fork seal driver.
Or, you can make your own fork seal driver for about $3.  You will need the following:
2 foot section of 2 inch schedule 40 PVC pipe,
One 2 inch endcap for above section of pipe,
1 piece of 1-1/4 inch PVC pipe COUPLER,
One 4 to 6 inch length of 2x4 lumber.
Some manufacturing skills are required:
Install cap onto PVC pipe section.  This is what you will use to hammer the seal into position.
On 1-1/4 inch PVC coupler, there is a step/stop ridge in the ID of the coupler, grind it down flush with the ID of the fitting.  You will notice that the coupler is a nice fit onto the FJ fork tube.
Next, take the 2x4 and drill a 41+mm hole in it so it fits over the fork tube.
Now you are ready for assembly:
With tapered spindle (cone shaped piece) on end of fork tube, install damper rod with top-out spring into fork tube.
Making sure tapered spindle stays in place, install fork tube into slider.
Install 10mm allen bolt to hold damper rod in place.
Be aware of damper rod alignment and damper alignment screw (see manual) and use damper rod holding tool to hold DR in place while you tighten it down.
From top of fork tube, install upper bushing and washer.  You should be able to press upper bushing into position by hand,
Next comes the fork seal.  Make sure you don't install it upside down!  Oil it up good it's easier to press into position.
Push fork seal into position on top of fork slider.
Install 1-1/4 inch PVC coupler on top of fork seal.
Next is 2x4 wood adapter.
Now, slide the 2 inch PVC pipe with end cap over fork tube and hammer seal into place.
Remove pipe, 2x4, and coupler.
Verify you can see the wire keeper groove above the seal.
Depending on year model, there may be another washer above the seal.
Install keeper wire and dust cover and you'll be ready to add oil.
Add specified amount of oil then pump fork to distribute oil and displace air.
This is where you collapse fork and measure fork oil distance from  top of fork.  Typical height is 120 to 140mm from top of tube.
Next extend fork and install fork spring.
Now, do yourself a BIG favor.  With the spring installed and the tube fully extended, re-measure the fork oil height and WRITE THIS DOWN!  That way next time you want to change the oil you can do it with out tearing the whole front end down just so you can compress the fork tube.  Trust me, this will turn a 3 hour job into 20 minutes.
Install spacer, washers and top cap and you're done!
For the finished fork, assembly is the reverse of removal.
One final thing.  If you still have anti-dive forks, you might want to disable the A/D while you have them apart.  This is very easy to do while you have the damper rod out.  Simply drill two 5/16th inch holes 180 degrees apart in the DR above the step for the tapered spindle.  This will provide a route for the oil to bypass the A/D unit.
Final, final thing.  If you have A/D, be sure to account and re-install the 3 washers above the tapered spindle.  There are two flat washers with a wave washer between them.  Also, tapered spindle installs with tapered end facing top of fork.
There, a bunch of information that you didn't ask for.  :-)
But, as others have said, you can add oil to your forks to avoid all this.  I would also add caution that the leaking oil does not contaminate the brake caliper seals.  It will.
Quote from: FJ_Hooligan on November 14, 2017, 05:06:32 PM
David, it is almost 2018, there is no trouble finding the proper tools you need for working on your FJ forks.
They are always in stock at RPM.
27mm Fork Tool
41mm Fork Seal Driver
Fork Level Gauge
Plus, everything else you need to do the job right the first time.
FJ 41mm Fork Seal & Wiper Kit ~OR~ RPM/FJ 41mm Fork Rebuild Kit
Some additional parts to ensure you don't experience leaks elsewhere after reassembly.
Gasket, Copper Fork Damper Washer
Fork Leg Drain Screw Washer
Fork Leg Drain Screw (Allen Head)
Motul Factory Team Line 10wt Fork Oil
Here is the RPM fork brace to stiffen up the assembly, This allows the bushings & seals to live longer.
RPM Fork Brace
In the event Ryan wants install the best upgrade for your FJ forks, here are the parts needed for that.
RPM Fork Valve
Front Fork Spring .85kg/mm
Motul Factory Team Line 5wt Fork Oil
RPM has the seal mate in stock as well: Seal Mate
