Carb balancing - connecting vacuum guages
Started by shudnobetter, September 12, 2017, 03:52:22 PM
shudnobetter
As a relative newbie I'm learning as I go.
My question is where exactly do I connect the vacuum hoses from a vacuum manometer on my carbs (1990 3cv)?
Thanks in anticipation.
If at first you don\'t succeed, maybe parachute jumping isn\'t for you!
Flynt
Quote from: shudnobetter on September 12, 2017, 03:52:22 PM
Connect to the barbs between the carbs and the engine on the intake boots...  You should have 3 of the barbs capped off and one with a hose going to the control box.  Remove the caps and the hose, attach your vacuum gauges and get busy...
PaulG
The carb manifolds on the inlet ducts for the motor have a vacc spigot sticking straight up. They should have a rubber cap on them - usually with a spring clamp.
This is a pic from my FJ600 which shows them . The 1200 is the same set up.
1992 FJ1200 ABS
YouTube Channel Paul G
shudnobetter
Quote from: Flynt on September 12, 2017, 09:18:44 PM
Great, thanks. All 4 are capped (may be different specs US/Europe) but they're obvious enough.
shudnobetter
Quote from: PaulG on September 12, 2017, 09:34:48 PM
Perfect...couldn't be more clear. I was guessing that was them but needed to be sure. Delighted I don't need that wretched airbox out again!
