Throttle Return
Started by WHYNOT_FJ, September 02, 2017, 11:19:04 PM
WHYNOT_FJ
Am having a problem with the Throttle return..or not returning/springing back as it should. With having none to minimal mechanical experience, what's the fix?
Is the attached pic likely to be the culprit?  Hope photo attaches..
How/ where to go to fix..and any insight on cost..dare i ask how rare this part is likely to be
Need this and new tyre before Mapleton..
Andrew
That certainly is a problem even if it not causing your current issue. Mine broke at the throttle. It still worked but I replaced it anyway. A stuck open throttle can be very bad.
Bones
Andrew, have you tried holding the broken part upright to see if it still sticks. Either way you still need new throttle cables, I don't know if you can get them singular or as a pair. I assume their still available from Yamaha, if not Randy should have them.
Actually, I remember at my shed day Harvy bringing a few parts with him and I'm sure he had new throttle cables amongst it. If Yamaha don't have any it might pay to contact him and see if he's still got them and willing to sell them.
93 fj1200
79 suzuki gt250x7
My gut feeling is that what is pictured, is exactly your throttle return issue. RPM does stock the throttle cables that you need. They come as a pair, and I would highly recommend replacing both cables.
Throttle cable pair.... http://rpmracingca.com/proddetail.asp?prod=M%2FC%3A91-93TC
WHYNOT_FJ
Thanks Gents
I have ordered a new throttle cable..hoping to get a chance to pull throttle apart inspect clean and lubricate.
Andrew
