Really bad oily smoke on start up :-(
Started by Josh.vesey, August 22, 2017, 07:07:03 AM
Josh.vesey
Hi folks.
Bike has had a service with 20/50.
Carbs cleaned  and balanced and valves checked. The bike is running lovely. But it smokes like a tractor when you start it up.
150 psi on all cylinders. The bike is using oil. Do you think its the valve stem seals? Cheers folks!
balky1
Quote from: Josh.vesey on August 22, 2017, 07:07:03 AM
Hi folks.
There is a way of knowing it, I'm just not sure if I'm going to write it correctly:
while you ride if it smokes on hard throttle then the piston rings are bad and if you close the throttle from high RPMs and  smokes, then the valve stem seals are to blame.
Or is it the other way around....  :scratch_one-s_head: :scratch_one-s_head:
Someone more experienced will correct me for sure.
Or you can search on the forum yourself, there are many posts about it. Use Google and include fjowners.com at the end of the search string.
FJ 1100, 1985, sold
FJR 1300, 2009
Josh.vesey
jscgdunn
Sounds like valve seals.  Oil pools to the left side on side stand.  Try storing on centre stand to see if it smokes less on start-up. Sounds like you have good compression.....I would just ride it!
90 FJ 1200 (Son # 2), Stock
Josh.vesey
Yeah cylinder 3 and 4 look oily in exhaust ports. Maybe a job for the winter then. It embarrasing more that anything. The smoke fills tge street when i start it up and it stinks.
Josh.vesey
Especially when my neighbours habe there bedroom window open  :sarcastic:
