Valve shim calculator
Started by Country Joe, August 13, 2017, 03:10:17 PM
Country Joe
Just wanted to share this valve shim calculator that i found yesterday. Makes figuring out your new shim thickness a piece of cake.
http://www.maultechatv.com/techguides/Valve%20Clearance%20Calculator/
1993 FJ 1200
It seems to provide the ideal shim size. But shims do not come in ideal sizes. However, it is just a calculator and knowing that a loose valve is happier than a tight valve this can be a good tool for any adjusting their valves.  Thanks for sharing your find.
