85 FJ - Valve cover pins
Started by getoutside3274, April 23, 2017, 10:19:20 AM
getoutside3274
Hello,
   so I've read in the service manual that when removing the valve cover there are two pins that you need to be careful of.  The book doesn't mention their location and I can find no mention of them on this site.  1 1/2 hours of searching (though I could not be entering the "right term"!).  Also the manual mentions using some type of sealant on the 4 "half moon" pieces of the gasket but most posts concerning this topic suggest not using anything.
   I know the sealant issue is a severely beaten horse but can anyone give me an idea of the location of the pins so that as I am taking the cover off, I sort of know where to look so they don't fall in?
Many thanks and this site is the best!!
Mike Courtemanche
I am not aware of any pins and I have adjusted the valves many times. They may be pressed in to the head to help index the cover.
Negative.
There are no pins on any of the valve covers I have ever taken off of FJ engines. 1100 or 1200.
There are also only (2) half-moons on the right (throttle) side of the engine, not 4.
getoutside3274
Well that's good to hear.  Nothing worse than the sound of something falling into an engine!
I just helped helped a friend today adjust the valves on his '89 and no pins were found.
CutterBill
I'm currently in the middle of a valve adjust on my '93.  No pins...
Bill
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
getoutside3274
Here is what prompted the question.  It comes from the Hayes workshop manual.
Thanks for the replies.  I should be replacing the gasket tomorrow.
The head has unused holes that could be for a dowel pin. But the gasket and cover do not. So no pins here on the FJ...
I believe the dowels/pins that are being asked about and referenced in the provided link are #3 in my attached drawing. Those dowels fit between the Cylinder block and the Head.
getoutside3274
Just changed it this morning, all is well!  The hardest part was taking off the 8 rubber gaskets from the hold down bolts!  As the music group Stain would say, "it's been a while".
