Are FJ1200 Coils all the same ,
Started by wainot-Phil, April 19, 2017, 11:08:49 PM
wainot-Phil
Hi ,,Just asking if all FJ1200 Coils Packs are the same through out the years ,,
Will Coils from a 1994 Model fit and run a 1986 Model ,,If not ,,what year did they change ,,
I am aware that the 2 Coil Packs are different as one feeds 1 and 4  and the other Coil feeds 2 and 3 ,,
thanks in advance ,,cheers
""Past Bikes""
Suzuki Stinger 125
Honda 350/4
Kawasaki Z1000
Suzuki GS1000
Kawasaki GPZ900R
Yamaha FJ1100 84
Yamaha FJ1100 85
1990 FJ1200  Pinky
2006 FJR1300
1980 GS850
Z500 /4
XJR1300
"""Present Bikes""":
FJ1200  94
GSX1400
Hey Phil, FYI a visit to my post will show you how to look up your answer:
http://www.fjowners.com/index.php?topic=5863.0
The FJ changed from a TCI (transistor controlled ignition) to a DCI (digitally controlled ignition) in '89
Also changed, the ignition trigger,  changed from a dual pick up ('84-87) to a single pick up ('89-93)
Therefore, it's not surprising that Yamaha shows 2 different part #'s for the coils
For '84-87 early FJ:  http://www.partzilla.com/parts/detail/yamaha/YP-36Y-82320-60-00.html
For the '89-93 late FJ  http://www.partzilla.com/parts/detail/yamaha/YP-3CV-82320-00-00.html
Going by memory, I recall the harness plugs to be different between the early and late model coils.
Sorry, I don't have access to the GYSM to look up the specs on the early vs late coils to see if they are different.
If you can wire around the different harness plugs, I *think* they should interchange, after all, the Dyna 3 ohm green coils works on both early and late FJ's
Others please chime in...
wainot-Phil
Hi Pat,,,OK Great,, thank you very much for the info,,regards Phil
[/quote]
""Past Bikes""
Suzuki Stinger 125
Honda 350/4
Kawasaki Z1000
Suzuki GS1000
Kawasaki GPZ900R
Yamaha FJ1100 84
Yamaha FJ1100 85
1990 FJ1200  Pinky
2006 FJR1300
1980 GS850
Z500 /4
XJR1300
FJ1200  94
GSX1400
yambutt
Well as said before both of my 1992 coils read 2.0 ohms so if the 87 to 84 coils were 3ohms they are definitely different
yambutt
Ok for the record so there is no confusion in the future this is what I got from dyna
Hello Thomas.
The Yamaha FJ models did change (stock) ignitions and subsequent coil primary
ohm ratings over the years, so it is critical the model year be verified.
The 1989 and 1990 1200 engines used a coil having a 2.4 to 3.0 ohm primary ohm
rating, so the 2.2 ohm coils should never be used with a stock ignition.
However, on the 1991 to 1993 1200 engines, this changed to a 1.8 to 2.2 ohm
rating. So, your 1992 model is perfectly safe using the DC4-1 coil set, rated
at 2.2 ohms if you have the stock or Dyna 2000 ignition system.
Thank you,
Larry Nelson
Technical Support
Dynatek
1-800-928-DYNA (3962)
http://www.dynaonline.com
My stock coils actually read 1.8 and 1.9 ohms 1992 fj
Thanks again Thomas.
I sent a PM to the OP ( wainot-phil)  letting him know what you've found.
Not to use the lower ohm '91-93 coils on the earlier FJ's.
Hopefully he didn't do any damage.
Pat
wainot-Phil
OK  ,Great ,,,Thank you  for the info Pat ,,
My 1987 1TX  Bike is set up with a XJR1200  Motor , I have fitted the 86/87 Analog 2 pole ignition pick-up  to the Motor to match the 1987 standard CDI  unit etc , I did find  that the 2 existing 1987 Coils had large cracks in the under side of both Coils  so I replaced the Coils with 2 secondhand Coils from ebay ,,  I have no idea what year model the Coils are that I have fitted to my 87 Bike , The 2 Coils I fitted  look exactly the same as the Cracked Coils . The 87 Bike is going good ,with out any misfires etc ,, I only just came home today from a 400 mile ride and its running smoothly ,,
BUT
Can any one PLEASE tell me how to identify the early model 86/87 Coils that I should have fitted to my 87 FJ  so to match my fitted  87 ignition Pick-up and the standard 87  1TX  CDI  Box ,,,
Thanks again for advising me that the FJ1200  Coils have changed over the years,,,
regards Phil
""Past Bikes""
Suzuki Stinger 125
Honda 350/4
Kawasaki Z1000
Suzuki GS1000
Kawasaki GPZ900R
Yamaha FJ1100 84
Yamaha FJ1100 85
1990 FJ1200  Pinky
2006 FJR1300
1980 GS850
Z500 /4
XJR1300
FJ1200  94
GSX1400
yambutt
Phil contact dyna, they will tell you what you need to know
wainot-Phil
Ok  thanks ,, ,,I have just sent them a message asking how to identified the FJ Coils ,,
cheers Phil
""Past Bikes""
Suzuki Stinger 125
Honda 350/4
Kawasaki Z1000
Suzuki GS1000
Kawasaki GPZ900R
Yamaha FJ1100 84
Yamaha FJ1100 85
1990 FJ1200  Pinky
2006 FJR1300
1980 GS850
Z500 /4
XJR1300
FJ1200  94
GSX1400
Do what Thomas did....check the primary ohm values.
2.4 to 3.0 ohms will show that they are the early coils.
1.8 to 2.2 ohms will show that they are the '91-93 coils.
