Swing arm and shock fitmet
Started by Mike m, March 23, 2017, 07:37:06 PM
Mike m
I'm in the process of fixing my tired suspension.i received my shock today and need help with tolerances.Are these parts supposed to move a slotted amount side to side.help please
Mike, it looks like you have an 86/87 from the picture you posted. The FJ has 4 different generations so when asking for help/information providing the year of your bike really helps. Your question about a slotted amount needs more detail about what you think the problem is.
balky1
I'll give it a go, FJMonkey.
I think the manual says that no side-play is allowed (that means when you assemble everything and grab the swing arm, it shouldn't have any side-play). Also when you bolt everything together and move the wheel up-down, some free-play is allowed but nut much.
FJ 1100, 1985, sold
FJR 1300, 2009
Mike m
Those two pieces are joined together along with the shock with a axle type rod,I've got no side to side movement at my swingarm but those 2 pieces have some side to side play is this normal?
balky1
As long as the bearings are good, I don't think it is a problem.
Maybe someone with more experience can confirm or disprove this.
FJ 1100, 1985, sold
FJR 1300, 2009
